translation-rules
The translation-rules element creates unique sets of translation rules to apply to calling and called party numbers. The fields within this element specify the type of translation to be performed, the addition for deletion to be made, and where in the address that change should be made.
Parameters
- id
- Enter the identifier or name for this translation rule. This field is required.
- type
- Select the address translation type to be performed
- Default: none
- Values:
- add—Adds a character or string of characters to the address
- delete—Deletes a character or string of characters from the address
- replace—Replaces a character or string of characters within the address
- none—Translation rule is disabled
- add-string
- Enter the string to be added during address translation to the original address. The value in this field should always be a real value; i.e., this field should not be populated with at-signs (@) or dollar-signs ($).
- add-index
- Enter the location in the original address where the string specified in the add-string value is inserted. This value is the character position starting at 0 to insert the add-string value.
- delete-string
- Enter the string to be deleted from the original address during address translation. Unspecified characters are denoted by the at-sign symbol (@).
- delete-index
- Enter the location in the address to delete the string specified in the delete-string field. This value of this field is the character position starting at 0 to insert the add-string value. This is not used when only deleting a given string.
- Default: 0
- Values: Min: 0 / Max: 999999999
Path
translation-rulesis an element under the session-router path. The full path from the topmost ACLI prompt is:
You can delete unspecified characters from an original address by using the at-sign (@). This is a multiple instance configuration element.
