tscf-protocol-policy
Configures the protocol policy to enable Policy-based forwarding.
Parameters
- name
- Name of this protocol policy configuration element.
- ip-address
- Criteria to match inner tunnel packet's destination IP against. For non-tunneled packets, this parameter is matched against the source IP Address. This parameter is optional. This parameter supports an IPv4 or IPv6 address.
- port
- Criteria to match inner tunnel packet's destination port against. For non-tunneled packets, this parameter is matched against the source port. This parameter is optional.
- transport-type
- Criteria to match inner tunnel packet's transport protocol.
- Default: empty
- Values: UDP | TCP | TLS | SCTP
- realm-id
- The egress realm where this protocol policy forwards matching packets. Those packets are forwarded to the gateway that services the interface associated with the named realm.
- remote-ip-address
- An optional post-NAT destination IP address target of detunneled packets matching this protocol policy. When matching traffic is forwarded from the non-tunneled side to tunneled side, the source IP address must match the remote-ip-address. The source IP address will be changed back to the original destination IP address within the tunneled packet.
Path
tscf-protocol-policy is an element within the path. The full path from the topmost ACLI prompt is
