account-config
The account-config configuration element allows you to set the location where accounting messages are sent.
Parameters
- port
- Enter the UDP port number from which RADIUS messages are sent
- Default: 1813
- Values: Min: 1025 / Max: 65535
- strategy
- Select the strategy used to select the current accounting server
- Default: Hunt
- Values:
- hunt—Selects accounting servers in the order in which they are listed
- failover—Uses first and subsequent servers in accounting server list until a failure is received from that server
- roundrobin—Selects accounting server in order, distributing the selection of each accounting server evenly over time
- fastestrtt—Selects accounting server with the fastest RTT observed during transactions with the servers
- fewestpending—Selects accounting server with the fewest number of unacknowledged accounting messages
- protocol
- Set the type of message protocol type for accounting CDRs.
- Default: radius
- Values: radius | diameter
- state
- Enable or disable the accounting system
- Default: enabled
- Values: enabled | disabled
- max-msg-delay
- Enter the time in seconds the
Oracle Communications Session Border Controller continues to send each accounting message
- Default: 60
- Values: Min: 0 / Max: 4294967295
- max-wait-failover
- Enter the number of accounting messages held in message waiting queue before a failover situation status is enacted
- Default: 100
- Values: Min: 1/ Max: 4096
- trans-at-close
- Enable the
Oracle Communications Session Border Controller to transmit accounting message information at the close of a session only. Setting this parameter to disabled tells the
Oracle Communications Session Border Controller to transmit accounting information at the start of a session (Start), during the session (Interim), and at the close of a session (Stop).
- Default: disabled
- generate-start
- Select the type of SIP event that triggers the
Oracle Communications Session Border Controller to transmit a RADIUS Start message
- Default: ok
- Values:
- none—RADIUS Start message is not generated
- invite—RADIUS Start message is generated once a SIP session INVITE is received
- ok—RADIUS Start message is generated an OK message in response to an INVITE is received
- generate-interim
- SBC to transmit a RADIUS Interim message
- Default: reinvite-response
- Values:
- ok—RADIUS Start message is generated when an OK message is received in response to an INVITE
- reinvite—RADIUS Interim message is generated when a SIP session reINVITE message is received
- reinvite-response—RADIUS Interim message is generated when a SIP session reINVITE is received and the system responds to it
- reinvite-cancel—RADIUS Interim message is generated when a SIP session reINVITE is received, and the Reinvite is cancelled before the Oracle Communications Session Border Controller responds to it
- unsuccessful-attempt—RADIUS Interim message is generated when a session set-up attempt from a preference-ordered list of next-hop destinations is unsuccessful. This can happen when a local policy lookup, LRT lookup, ENUM query response, or SIP redirect returns a preference-ordered list of next-hop destinations. The interim message contains: the destination IP address, the disconnect reason, a timestamp for the failure, and the number that was called
- Egress-Invite—Sends additional Interim message is generated when applicable VoLTE and WiFi INVITEs egress the system
- generate-event
Enter one or more valid events that prompt creation of an Event record. Current valid values are register and local-register. Multiple values are entered enclosed in parenthesis and separated by spaces.
- Default:
- Values: register | local-register
- file-output
- Enable or disable the output of comma-delimited CDRs
- Default: disabled
- file-path
- Enter the path in which to save the comma-delimited CDR file. Most common settings for this parameter are /ramdrv or /ramdrv/logs directories. You cannot set this parameter to the /code or /boot directories.
- max-file-size
- Set the maximum file size in bytes for each CDR file
- Default: 1000000
- Values: Min: 1000000 / Max: 100000000
- max-files
- Set the maximum number of files to store on the
Oracle Communications Session Border Controller. The parameter's value range is from 0 to unlimited. The user should consider the
max-file-size setting and available space to specify this value.
- Default: 5
- file-seq-number
- When enabled, the system assigns a 9 digit file sequence number to append to a CDR file.
- Default: disabled
- enabled
- file-compression
- Enable or disable compression of CDR files; when enabled, comma-delimited CDR files are zipped on the backup device to maximize storage space
- Default: disabled
- file-rotate-time
- Set the time in minutes that the
Oracle Communications Session Border Controller rotates the CDR files; the
Oracle Communications Session Border Controller will overwrite the oldest file first
- Default: 60
- Values: Min: 2 / Max: 2147483647
- file-delete-alarm
- Enable or disable the raising of an alarm when CDR files are deleted due to lack of space.
- Default: disabled
- ftp-push
- Enable or disable the FTP push feature
- Default: disabled
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - ftp-address
- Enter the IP address for the FTP server used with the FTP push feature.
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - ftp-port
- Set the TCP port on the FTP server to use with the FTP push feature
- Default: 21
- Values: Min: 1 / Max: 65535
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - ftp-user
- Enter the username the
Oracle Communications Session Border Controller will use to log in to the FTP server.
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - ftp-password
- Enter the password the
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - ftp-remote-path
- Enter the file path the
Oracle Communications Session Border Controller will use to work in on the FTP server.
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - ftp-strategy
- Set the strategy for the
Oracle Communications Session Border Controller to use when selecting from multiple push receivers.
- Default: hunt
- Values:
- hunt—The Oracle Communications Session Border Controller selects the push receiver from the available list according to the priority level
- failover—The Oracle Communications Session Border Controller selects the push receiver based on priority level and continues to use that same push receiver until it fails over
- roundrobin—The Oracle Communications Session Border Controller selects push receivers systematically one after another, balancing the load among all responsive push receivers
- fastestrtt—The Oracle Communications Session Border Controller selects the push receiver based on best average throughput. For this situation, throughput is the number of bytes transferred divided by the response time. The system uses a running average of the five most recent throughput values to accommodate for network load fluctuations
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - intermediate-period
- Set the time interval used to generate periodic interim records during a session
- Default: 0
- Values: Min: 0 / Max: 999999999
- account-servers
- Access the account-server subelement
- cdr-output-redundancy
- Enable or disable the redundant storage of comma-delimited CDR files. The standby-push value ensures consistent and accurate CDR collection in the event of a failover.
- Default: enabled
- Values: enabled | disabled | standby-push
- ftp-max-wait-failover
- Enable or disable the prevention of duplicate accounting attributes
- Default: 60
- Values: Min: 1 / Max: 4096
This parameter is deprecated and is only used if no account-config > push-receiver configuration element has been defined. All new push receivers must be defined in the account-config > push-receiver configuration element. - prevent-duplicate-attrs
Enable this parameter to prevent the Oracle Communications Session Border Controller from duplicating attributes in the accounting records it generates. This duplication can be caused, for example, by multiple media sessions within the context of a call. Retaining the default (disabled) allows the Oracle Communications Session Border Controller to include duplicate attributes in RADIUS, Diameter and Local accounting records. This can result in attribute placement and counts that are less consistent.
- Default: disabled
- vsa-id-range
- Enter the range of accounting attributes to include in CDRs. A blank field means this feature is turned off and all attributes are included.
- cdr-output-inclusive
- Enable or disable the guarantees placement of attributes in CSV files used for local CDR storage and FTP push
- Default: disabled
- push-receiver
- Access the push-receiver subelement.
- watchdog-ka-timer
- Sets the value in seconds that the
Oracle Communications Session Border Controller waits between sending DWRs.
- Default: 0
- Values: 0,6-65535
- msg-queue-size
- Sets the message queue sizefor both RADIUS and Diameter accounting interfaces.
- Default: 5000
- Values: 5000-15000
- diam-srvc-ctx-ext
- Value to substitute in the extension portion of the Service-Context-ID AVP value. This value can be any string.
- diam-srvc-ctx-mnc-mcc
- Value to substitute in the MNC.MCC portion of the Service-Context-ID AVP value. This value must follow the NUM1.NUM2 format.
- diam-srvc-ctx-rel
- Value to substitute in the release portion of the Service-Context-ID AVP value. This value can be any number>=1.
- diam-acme-attr-id-range
- The range of Acme-specific AVP’s to include in ACR messages.
- max-acr-retries
The maximum number of times that the SBC can resend an ACR for a session.
- Default: 0
- Values: 0 - 4
- acr-retry-interval
The time in seconds for the SBC to wait before resending an ACR for a session.
- Default: 10
- Values: 5 - 20
Path
account-configis an element of the session-router path. The full path from the topmost ACLI prompt is. .
This is a single instance configuration element.
