account-config > account-servers
The account-server configuration subelement stores the accounting server information for the account-config.
Parameters
- hostname
- Enter the hostname of the accounting server. Entries are in FQDN or IP Address Format
- port
- Enter the UDP port number associated with the accounting server is configured here
- Default: 1813
- Values: Min: 1025 / Max: 65535
- state
- Enable or disable this account-server
- Default: enabled
- Values: enabled | disabled
- min-round-trip
- Enter the time in milliseconds of the minimum RTT for an accounting message for use with the fastest RTT strategy method
- Default: 250
- Values: Min: 10 / Max: 5000
- max-inactivity
- Enter the maximum time in seconds the
Oracle Communications Session Border Controller waits when accounting messages are pending without a response before this account server is set as inactive for its failover scheme
- Default: 60
- Values: Min: 1 / Max: 300
- restart-delay
- Enter the time in seconds the
Oracle Communications Session Border Controller waits after declaring an accounting server inactive before resending an accounting message to that same accounting server
- Default: 30
- bundle-vsa
- Enable or disable the bundling of the VSAs within RADIUS accounting on the account-server
- Default: enabled
- secret
- Enter the secret passed from the account-server to the client server; entries in this field must follow the Text Format
- NAS-ID
- Enter the value the account-server uses to identify the Oracle Communications Session Border Controller so messages can be transmitted; entries in this field must follow the Text Format
- priority
- Enter the number corresponding to the priority for this account server to have in relation to the other account servers to which you send traffic. The default is 0, meaning there is no set priority.
- Default: 0
- Values: Min: 0
Path
account-server is a subelement of the account-config element. The full path from the topmost ACLI prompt is: .
This list can contain as many accounting servers as necessary. By default, this list remains empty. RADIUS will not work unless an account server is configured. This is a multiple instance configuration element.
