account-config > push-receiver
You can configure multiple CDR push receivers for use with the FTP push feature.
Parameters
- server
- Send the IP address of the FTP/SFTP server to which you want the
Oracle Communications Session Border Controller to push CDR files
- Default: 0.0.0.0
- port
- Enter the port number on the FTP/SFTP server to which the
Oracle Communications Session Border Controller will send CDR files.
- Default: 21
- Values: Min: 1 / Max: 65535
- admin-state
- Set the state of an FTP/SFTP push receiver to enabled for the
Oracle Communications Session Border Controller to send CDR files to it
- Default: enabled
- Values: enabled | disable
- remote-path
- Enter the pathname on which the CDR files are sent to the push receiver. CDR files are placed in this location on the FTP/SFTP server.
- Default: non
- Values: <string> remote pathname
- filename-prefix
- Enter the filename prefix to prepend to the CDR files the
Oracle Communications Session Border Controller sends to the push receiver. The
Oracle Communications Session Border Controller does not rename local files.
- Default: none
- Values: <string> prefix for filenames
- priority
- Enter a number 0 through 4 to set the priority of this push receiver in relation to the others you configure on the system. The highest priority—and the push receiver the system uses first—is 0. The lowest priority—and the push receiver the system uses last—is 4.
- Default: 4
- Values: Min: 0 (highest) / Max: 4 (lowest)
- protocol
- Select the transport protocol to be used for this push receiver. If this is an STFTP push receiver, enter the public-key information in the appropriate parameter in this configuration subelement.
- Default: ftp
- Values: ftp | sftp
- username
- Enter the username the Oracle Communications Session Border Controller uses to connect to push receiver.
- public-key
- Enter the public key profile to use for authentication when the server is defined for SFTP push receiver. If you define this as an SFTP push receiver but do not set a public-key value, the Oracle Communications Session Border Controller will use password authentication.
- temp-remote-file
- When enabled, the system prepends the characters "tmp-" to a CDR file during transfer.
- Default: disabled
- enabled
Path
push-receiver is a subelement under the account-config element. The full path from the topmost ACLI prompt is: configure terminal > session-router > account-config > push-receiver.
