ext-policy-server
The ext-policy-server is used for configuring PDP/RACF or CLF functionality on the Oracle Communications Session Border Controller.
Parameters
- name
- Enter the name of this external policy server configuration
- state
- Enable or disable
the operational state of this external policy server configuration
- Default: enabled
- Values: enabled | disabled
- operation-type
- Select the
function this external policy server performs
- Default: disabled
- Values:
- disabled
- admission-control—Oracle Communications Session Border Controllercommunicates with a CLF to obtain location string
- bandwidth-mgmt— Oracle Communications Session Border Controller acts as a PEP in a PDP/RACF deployment
- protocol
- Select the
external policy server communication protocol
- Default: C-SOAP
- Values:
- COPS—Standard COPS implementation. COPS client type is 0x7929 for CLF, and 0x7926 for PDP/RACF usage as defined in the operation-type parameter.
- A-COPS—Vendor specific protocol. COPS client type is 0x4AC0 for admission-control operation-type.
- SOAP—Not used
- C-SOAP—Not used
- DIAMETER—Connects the Oracle Communications Session Border Controller to the policy-server
- address
- Enter the IP address or FQDN of an external policy server, or enter the name of a policy-group preceded by the PSG: prefix. IP addresses can by IPv4 or IPv6.
- port
- Enter the port on
the external policy server to which you must connect. For example, the standard
port for COPS is 3288. The system ignores this parameter if the address
parameter is set to a policy-group or an FQDN.
- Default: 80
- Values: Valid Range: 0-65535
- realm
- Enter the realm where the external policy server exists. The system ignores this parameter if the address parameter is set to a policy-group, with the exception that it is used to populate all Origin-Realm and Origin-Host AVPs in diameter messages generated by traffic from the policy-group's policy-agents.
- transport-protocol
- Enter the transport protocol used to connect to this external
policy server.
- Default: TCP
- Values: TCP / SCTP
- local-multi-home-addrs
- Applies to SCTP. Enter an IP address that is local to the OCSBC and can be used by this external policy server as an alternate connection point. This address must be the same type as the address parameter, either IPv4 or IPv6.
- remote-multi-home-addrs
- Applies to SCTP. Enter an IP addresses that can be used by this OCSBC as an alternate connection point. This address must be the same type as the address parameter, either IPv4 or IPv6.
- sctp-send-mode
- Applies to SCTP. Specifies the SCTP delivery mode. The default
value is
ordered. Valid
values are:
- ordered (Default)
- unordered
- num-connections
- Enter the number
of TCP connections to external policy server
- Default: 1
- Values: Min: 0 / Max: 65535
- reserve-incomplete
- Enable or disable
admission requests being made before all of the details of the call are known
- Default: enabled
- Values:
- Enabled—Supports the usual behavior when the AAR is sent upon SDP offer as well as SDP answer. This mode ensures backwards compatibility with releases prior to Release S-C6.1.0.
- Orig-realm-only—Allows calls originating from a realm with a policy server associated with it to send the AAR upon SDP offer; calls terminating at a realm with a policy server associated with it send the AAR post SDP exchange.
- Disabled—Allows no bandwidth reservation for incomplete flows.
- permit-conn-down
- Enable or disable
the
Oracle Communications Session Border Controller’s ability to permit calls if there is no connection
to the external policy server.
- Default: disabled
- permit-on-reject
- Change this
parameter to enabled if you want the
Oracle Communications Session Border Controller to forward the session on at a “best-effort”. Leave
this parameter set to disabled (Default), if you want the
Oracle Communications Session Border Controller to deny the session on attempts to revert to the
previously-requested bandwidth
- Default: disabled
- permit-on-reject
- Change this
this parameter set to disabled (default), if you want the
previously-requested bandwidth.
- Default: disabled
- disconnect-on-timeout
- Disable this
parameter to prevent timeouts triggered by Gate-Set or Gate-Delete message
sequences between the
Oracle Communications Session Border Controller and a policy server from tearing down their
connection. Retaining the default (enabled) allows all timeouts to tear down
and re-establish the TCP connection.
- Default: enabled
- product-name
- Enter the vendor product name.
- application-mode
- Select the mode in
which the policy server interface is operating.
- Default: none
- Values: Rq | Rx | Gq | e2 | pktmm3
- application-id
- Enter the
application mode of this interface.
- Default: 0
- Values: Min: 0 / Max: 999999999
- framed-ip-addr-encoding
- Set the format of
the Frame-IP-Address (AVP 8) value in Diameter messages.
- Default: octet-string
- Values: octet-string (i.e., 0xC0A80A01) | ascii-string (i.e., 192.168.10.1)
- dest-realm-format
- Set the format for
the Destination-Realm AVP.
- Default: user_with_realm
- Values: user_with_realm | user_only | realm_only
- ingress-realm-location
- Set this parameter
to configure the child realm or its parent for the Address-Realm in the
Globally-Unique-Address AVL in DIAMETER UDR messages that the
Oracle Communications Session Border Controller sends to the policy server.
- Default: realm-in
- Values:
- realm-in—This setting means that the Oracle Communications Session Border Controller will use the same realm on which the REGISTRATION request arrived.
- sip-interface—This setting means that the Oracle Communications Session Border Controller will use the realm associated with the SIP interface on which the REGISTRATION request arrived.
- diam-address-realm - For the e2 interface, this value enables configurable Address-Realm AVPs. This setting points the Oracle Communications Session Border Controller to the associated realm from which it will learn Address-Realm AVP information.
- user-name-mode
- Determines how the
User-Name AVP is constructed. Used primarily with e2 based CLF functionality.
- Default: none
- Values:
- none—Oracle Communications Session Border Controller does not include the User-Name AVP in any UDRs
- endpoint-ip—IP address of the registering endpoint is sent as the payload for the User-Name AVP
- public-id—SIP-URI portion of the TO header from the register message is sent as the payload for the User-Name AVP
- auth-user—Username attribute of the Authorization header from the register is sent as the payload for the User-Name AVP; if there is no authorization header, the Oracle Communications Session Border Controller will not consult the CLF and will forward the registration message.
- domain-name-suffix
- Sets the suffix
for Origin-Realm and Origin-Host AVPs that have a payload string constructed as
a domain name. If your entry does not include the dot, the system prepends one.
- Default: .com
- gate-spec-mask
- With this
parameter, you can configure the
Oracle Communications Session Border Controller to use a mask comprised entirely of zeros (0). The
default value is 255. This parameter sets the value to use for the COPs
pkt-mm-3 interface. This interface maintains a persistent TCP connection to the
external policy server, even without repsonses to requests for bandwidth. This
permits calls to traverse the
Oracle Communications Session Border Controller even though the external policy server either fails
to respond, or rejects the session.
- Default: 255
- Values: Min: 0 / Max: 255
- allow-srv-proxy
- Enable this
parameter if you want to include the proxy bit in the header. The presense of
the proxy bit allows the
Oracle Communications Session Border Controller to tell the external policy server whether it wants
the main server to handle the Diameter message, or if it is okay to proxy it to
another server on the network (disabled)
- Default: enabled
- wildcard-trans-protocol
from enabled if you want to use transport protocol wildcarding for Rx/Rq
Flow-Description AVP (507) generation. Enabled sends a flow description of
“ip”. Set this parameter to disabled if you want to use the specific media
stream transport protocol.
- Default: disabled
- watchdog-ka-timer
- Enter the number
of seconds to define the interval for watchdog/keep-alive messages; this is the
time in which the
Oracle Communications Session Border Controller must receive a COPS-KA message from the policy server
to ensure collection is still valid.
- Default: 0
- include-rtcp-in-request
- Change this
parameter from disabled (default), to enabled so the
Oracle Communications Session Border Controller will include RTCP information in AARs.
- Default: disabled
- provision-signaling-flow
- Enables the
Oracle Communications Session Border Controller to send AARs to PCRFs after registration that
includes the grouped Media-Component-Description AVP as described in 3GPP TS
29.213 section B1b [1], and the procedures specified in TS 29.214 section
4.4.5a.
- Default: disabled
- max-timeouts
- max number of
request timeouts before the
Oracle Communications Session Border Controller sets this external policy server to inactive.
- Default: 0
- Values: Min: 0 / Max: 200
- max-connections
- Number of external
policy servers to be monitored as a server cluster
- Default: 1
- srv-selection-strategy
- Strategy used to
select an external policy server from the cluster.
- Default: Failover
- optimize-aar
- Reduces the number
of ARRs sent to the PCRF.
- Default: disabled
- cache-dest-host
- Used to enable the
Diameter Multi-tiered Policy Server Support feature.
- Default: disabled
- specific-action-subscription
- Populates the
Specific-Action AVP in an AAR message to indicate the subscription types it
supports. When unconfigured, no Specific-Action AVP is sent.
- Default: blank
- Values:
- loss-of-bearer
- recovery-of-bearer
- release-of-bearer
- out-of-credit
- successful-resources-allocation
- failed-resources-allocation
- access-network-info-report
- specific-action-sig-flow-subscription
- subscribes for signaling flow status change notifications
- diameter-in-manip
- Configure this parameter with the name of a diameter-manipulation to be applied on traffic inbound to the Oracle Communications Session Border Controller.
- diameter-out-manip
- Configure this parameter with the name of a diameter-manipulation to be applied to outbound traffic from this Oracle Communications Session Border Controller.
- asynchronous-mode
- Identifies whether
to use the asynchronous mode of signaling on the external policy server
interface rather than the default synchronous mode.
- Default: disabled
- media-release
- For scenarios
wherein the SBC releases media, enabling this parameter allows the policy
server request to include flow descriptions that accurately represent the IP
addresses of the two endpoints instead of that of the
- Default: disabled
- options
- Enter any customer-specific features and/or parameters for this external policy server. This parameter is optional.
Path
ext-policy-server is an element under the media-manager path. The full path from the topmost ACLI prompt is: .
