PreviousNextJavaScript must be enabled to correctly display this content
filter-config
The
filter-config element is used for configuring a filter object for SIP Monitor and Trace functionality.
Parameters
name
Enter the name of this filter-config configuration element.
address
IP Address to apply to this filter. The netmask is optional.
Default: 0.0.0.0
<addr-prefix><ipv4|ipv6> [/<num-bits>]
user
Phone number or user-part to apply to this filter.
Path
filter-config is an element under the session-router path. The full path from the topmost ACLI prompt is:
configure terminal > session-router > filter-config.
