h323
The h323 configuration element is the top level of the H.323 configuration, and it contains h323 parameters that apply globally.
Parameters
- state
- Enable or disable H.323 functionality.
- Default: INFO
- Values: EMERGENCY | CRITICAL | MAJOR | MINOR | WARNING | NOTICE | INFO | TRACE | DEBUG
- log-level
- Select the log level for monitoring H.323 functionality. This parameter overrides the process-log level field value set in the system-config element only for H.323 functionality. If the state parameter in this element is set to disabled, this parameter still overrides the process-log-level field from the system-config element for H.323.
- Default: INFO
- response-tmo
- Set the number of seconds
Oracle Communications Session Border Controller waits between sending a SETUP message and receiving no response before the call is torn down
- Default: 4
- Values: Min: 0 / Max: 999999999
- connect-tmo
Oracle Communications Session Border Controller waits between sending out a SETUP message and failing to receive a CONNECT message before the call is torn down. If the
Oracle Communications Session Border Controller receives a PROCEEDING or ALERT message from the endpoint, it will tear down the session after this timer elapses if a CONNECT message is not received.
- Default: 32
- options
- Enter customer-specific features and/or parameters that affect H.323 behavior globally. This parameter sets a comma-separated list of “feature=value” or “feature” parameters.
- h323-stacks
- Enter the h323-stacks subelement.
- rfc2833-payload
- Enter the payload type used by the H.323 stack in preferred rfc2833-mode
- Default: 101
- Values: Valid Range: 96-127
- alternate-routing
- Choose between pre-4.1 or 4.1 behavior:
- Pre-4.0 behavior—Alternate routing is disabled, and the Oracle Communications Session Border Controller sends a release complete message back to the caller, proxy
- 4.1 behavior—The
Oracle Communications Session Border Controller performs alternate routing, recur
- Default: proxy
- Values: proxy | recur
- codec-fallback
- Enable or disable slow start to fast start codec negotiation.
- Default: disabled
- Values: enabled | disabled
- enum-sag-match
- Enable or disable matching against the hostnames in ENUM/LRT lookup responses and session agent groups
- Default: disabled
- remove-t38
- Enable or disable the removal of t38 fax capabilities received in a SIP call’s SDP, from the TCS of the outgoing IWF call.
- Default: disabled
Path
h323 is an element under the session-router path. The full path from the topmost ACLI prompt is: .
Unlike other single-instance configuration elements, the h323 element does not have to be selected before it can be viewed. The options field does not appear in the output for the show command within the h323 element or for running-config subcommand unless it contains configured values. This is a single instance configuration element.
