rtcp-policy
The rtcp-policy is used to specify an individual rule controlling how the Oracle Communications Session Border Controller generates RTCP reports for the realm to which the rtcp-policy is assigned.
Parameters
- name
- Enter the name of this RTCP policy configuration. Use this name to assign the rtcp-policy to one or more realms.
- rtcp-generate
- Select the function this RTCP policy performs.
- Default: disabled
- Values:
- none—Disables this policy.
- all-calls—Oracle Communications Session Border Controller generates RTCP report information for all calls that pass through the realm.
- xcoded-calls-only— Oracle Communications Session Border Controller generates RTCP report information only for the transcoded calls that pass through the realm.
Path
rtcp-policy is an element under the media-manager path. The full path from the topmost ACLI prompt is: .
