rph-profile
The rph-profile contains information about how the Oracle Communications Session Border Controller should act on the namespace(s) present in Resource-Priority headers.
Parameters
- name
- Enter the name of this RPH profile; this is the value used when applying this RPH profile to an NMC rule.
- Default: none
- r-value
- Enter a list of one or more r-values used for matching; WPS values must be entered before ETS values.
- Default: none
- media-policy
- Default: none
- call-treatment
- Select the call treatment method for a non-ETS call that contains RPH matching this profile.
- Default: accept
- Values: accept | reject | priority
Path
rph-profile is an element under the session-router path. The full path from the topmost ACLI prompt is: .
