rph-policy
The rph-policy element defines an override resource value and an insert resource value for ETS/WPS namespaces. These are applied to NMC rules.
Parameters
- name
- Enter the name of this RPH policy; this is the value used when applying this RPH policy to an NMC rule.
- Default: None
- override-r-value
- Set the value the
Oracle Communications Session Border Controller uses to override the r-values in the original RPH.
- Default: None
- insert-r-value
- Set the value the Oracle Communications Session Border Controller inserts into the RPH.
Path
rph-policy is an element under the session-router path. The full path from the topmost ACLI prompt is: .
