redundancy > peers > destinations
The destinations subelement establishes locations where health and state information is sent and received.
Parameters
- address
- Enter the IP address and port on the interface of the HA Oracle Communications Session Border Controller peer where this HA Oracle Communications Session Border Controller peer sends HA messages. The parameter format is an IP address and port combination (IP address:port). This IP address must match the interface identified in its HA Oracle Communications Session Border Controller peer’s corresponding rdncy-peer-dest > network-interface field. The port portion of this parameter must match the port identified in its HA Oracle Communications Session Border Controller peer’s corresponding port field.
- network-interface
- Enter the name and subport ID of the interface where the HA Oracle Communications Session Border Controller receives HA messages (e.g., wancom1:0). Valid interface names are wancom1 and wancom2 only.
Path
destinationsis a subelement under the peers subelement. The full path from the topmost ACLI prompt is:
The destinations prompt is displayed as: rdncy-peer-dest. This is a multiple instance configuration element.
