redundancy > peers
The peers subelement establishes the name and state of an HA node.
Parameters
- state
- Enable or disable HA
- Default: enabled
- Values: enabled | disabled
- type
- Select the HA peer type and which utility address to use
- Default: unknown
- Values:
- primary—HA peer set as the primary Oracle Communications Session Border Controller. It is associated with the utility address configured in the pri-utility-addr field of each network-interface element.
- secondary—HA peer set as the secondary Oracle Communications Session Border Controller. It is associated with the utility address configured in the sec-utility-addr field of each network-interface element.
- unknown—Not assigned HA peer type with associated utility address unknown. This type field option is not valid for configuration checkpointing. Although unknown is the default value, Primary or Secondary field option must be set in order for configuration checkpointing to function properly.
- destinations
- Access the destinations subelement
Path
peers is a subelement under the redundancy element. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration subelement.
