backup-config
The backup-config command backs up the current flash memory configuration to the specified filename in the /code/bkups directory.
Syntax
backup-config <name-of-backup> [running | editing] [standard | non-standard]
Arguments
<name-of-backup> Enter the name of the backup configuration filerunning- Backup the configuration from the running configuration cache. This is an optional argument
editing- Backup the configuration from the editing configuration cache. This is an optional argument.
standard- Use standard XML as the file format
non-standard- Use non-standard, legacy XML for the file format
Mode
Superuser
Example
ORACLE# backup-config FEB_BACKUP.gz running
If insufficient disk space is available, the Oracle Communications Session Border Controller will not complete the task.
