arp-delete
The arp-delete command manually removes ARP entries from the ARP table.
Syntax
arp-delete <slot> <port> <vlan-ID> <ip-address>
Arguments
<slot> Select the media interface slotValues:
- 0—Left slot
- 1—Right slot
<port> Select the media interface port
Values:
- 0—Leftmost port
- 1— Second from left port
- 2 —Third from left port (not applicable for GigE cards)
- 3 —Rightmost port (not applicable for GigE cards)
<vlan ID> Enter the VLAN identifier
<ip-address> Enter the IP address
Mode
Superuser
Example
ORACLE# arp-delete 1 0 1 12.11.0.100
