arp-check
The arp-check command forces the SD to send an ARP request for the specified IP address. The command does not send an ARP request if the specified address is already in the ARP table or is in a different subnet.
Syntax
arp-check <slot> <port> <vlan-ID> <ip-address>
Arguments
<slot> Select the media interface slot
Values
- 0—Left slot
- 1—Right slot
<port> Select the media interface port
Values
- 0—Leftmost port
- 1— Second from left port
- 2 —Third from left port (not applicable for GigE cards)
- 3 —Rightmost port (not applicable for GigE cards)
<vlan ID> Enter the VLAN identifier
<ip-address> Enter the IP address
Mode
Superuser
Example
ORACLE# arp-check 0 0 0 11.21.0.10
