arp-add
The arp-add command manually adds ARP entries for media interfaces to the ARP table.
Syntax
arp-add <slot> <port> <vlan ID> <ip-address> <mac-address>
Arguments
<slot> Select the media interface slot
Values:
- 0—Left slot
- 1—Right slot
<port> Select the media interface port
Values:
- 0—Leftmost port
- 1— Second from left port
- 2 —Third from left port (not applicable for GigE cards)
- 3 —Rightmost port (not applicable for GigE cards)
<vlan ID> VLAN identifier
<ip-address> Enter the IP address
<mac-address> Enter the MAC address in hexadecimal notation
Mode
Superuser
Example
ORACLE# arp-add 1 0 0 172.16.1.102 ab:cd:ef:01:23:14
