archives
The archives command is used for creating, moving, and manipulating archived log files. All archive files are created in .tar.gz format in SD Software versions 2.0 and above. All commands are executed from within the archives menu.
Log files contain a record of system events. Log files are stored in the /code/logs directory. The CFG archive type is no longer supported in C6.2.0. When an archive command is entered with the CFG type, the Oracle Communications Session Border Controllerresponds with an error message.
Path
Type archives at the topmost prompt before executing any of the below commands to enter the archives shell.
Syntax
archives > create
create LOGS <logfile-name>
Arguments
<logfile-name> Enter the name of archive file that contains all logs To create an archive file of a log, type create LOGS and enter a logfile name. Archives are created in .tar.gz (tarred and gzipped) format.
Example
ORACLE(archives)# create LOGS jun_30.gz
Syntax
archives > delete
delete LOGS <logfile-name>
Arguments
<filename> Enter the filename of the log archive to delete The archives > delete command deletes the specified archive file from the Oracle Communications Session Border Controller. You must append “.tar.gz” to the filename when using this command. Use the archives > display command to list the available log archives to delete.
Example
ORACLE(archives)# delete LOGS july_16.gz
Syntax
archives > display
display LOGS
Arguments
This command lists the log archives currently saved on the Oracle Communications Session Border Controller’s file system.
Example
ORACLE(archives)# display LOGS
Syntax
archives > exit
exit
Example
ORACLE(archives)# exit
This command exits from the archives session and returns you to the ACLI Superuser system prompt.Syntax
archives > extract
This command is no longer supported in release C6.2.0.
Syntax
archives > get
get LOGS <archive-name> <remote-host> <user-name> <password>
Arguments
<remote-name> Enter the full path and filename to retrieve
<host> Enter the IP address of the remote host
<user-name> Enter the user name on remote host
<password> Enter the password on remote host
Example
ORACLE(archives)# get LOGS may_31.gz
This command retrieves an archived log. If you do not include all the necessary arguments, the get command will prompt you for the arguments you omitted. The get command writes the retrieved file to the /code/logs/<archive-name> path.Syntax
archives > rename
rename LOGS <old-archive> <new-archive>
Arguments
<current_name> Enter the old archive name
<new_name> Enter the new archive name
Example
ORACLE(archives)# rename LOGS june sept
Renames an archived log. You do not need to append “.tar.gz” to the filename when using this command.Syntax
archives > send
send LOGS <archive-name> <host-ip-address> <username>
Arguments
<archive-name> Enter the name of archive file to send
<host-ip-address> Enter the IP address of FTP server
<username> Enter the FTP username on server
Example
ORACLE(archives)# send LOGS Oct_24.gz 1.0.100.7 user1
This command sends an archived log file to a remote host using FTP. If you do not include all the necessary arguments, the send command will prompt you for the arguments you omitted.archives create
Syntax
Arguments
- <logfile-name> Enter the name of archive file that contains all logs
Example
archives delete
Syntax
Arguments
<filename> Enter the filename of the log archive to deleteThe archives > delete command deletes the specified archive file from the Oracle Communications Session Border Controller. You must append “.tar.gz” to the filename when using this command. Use the archives > display command to list the available log archives to delete.
Example
archives display
Syntax
display LOGS
This command lists the log archives currently saved on the Oracle Communications Session Border Controller file system.
Example
archives exit
Syntax
exit
This command exits from the archives session and returns you to the ACLI Superuser system prompt.Example
archives get
Syntax
Arguments
- <remote-name> Enter the full path and filename to retrieve
- <host> Enter the IP address of the remote host
- <user-name> Enter the user name on remote host
- <password> Enter the password on remote host
This command retrieves an archived log. If you do not include all the necessary arguments, the get command will prompt you for the arguments you omitted.The get command writes the retrieved file to the /code/logs/<archive-name> path.
Example
archives rename
Syntax
Arguments
- <current_name> Enter the old archive name
- <new_name> Enter the new archive name
Renames an archived log. You do not need to append “.tar.gz” to the filename when using this command.Example
archives send
Syntax
Arguments
- <archive-name> Enter the name of archive file to send
- <host-ip-address> Enter the IP address of FTP server
- <username> Enter the FTP username on server
This command sends an archived log file to a remote host using FTP. If you do not include all the necessary arguments, the send command will prompt you for the arguments you omitted.Example
