activate-config
The activate-config command activates the current configuration on the Oracle Communications Session Border Controller to make it the running configuration.
Syntax
activate-config
Mode
Superuser
Notes
Before executing this command, be aware of the real time configuration (RTC) consequences on the operation of the Oracle Communications Session Border Controller.To use RTC, the activate-config command is executed to alert the Oracle Communications Session Border Controller that the current configuration has changed and that it needs reload configuration information.
Example
ORACLE# activate-config
