acquire-config
The acquire-config command retrieves the configuration from oneOracle Communications Session Border Controller for configuration checkpointing an HA node.
Syntax
acquire-config <IPAddress>
Example:
Arguments
<IPAddress> Enter the IP address of the Oracle Communications Session Border Controller to acquire configuration from.
Mode
Superuser
Notes
This command forces one Oracle Communications Session Border Controller in an HA node to learn the configuration from the other system. If configuration checkpointing is already running, the acquire-config command has no effect.
Only after the acquire-config command is executed and the Oracle Communications Session Border Controller is rebooted will the process of acquiring the configuration be complete. In version 2.0, only type acquire-config <wancom0-IP address> .Example
ORACLE#acquire-config 1.1.0.1
