acl-show
The acl-show command shows a list of denied ACL entries.
Syntax
acl-show
Mode
Superuser
Notes
The acl-show command displays a list of the following denied ACL entries:
- Incoming port, slot, and VLAN tag
- Source IP, bit mask, port, and port mask
- Destination IP address and port
- Protocol
- ACL entry as static or dynamic
- ACL entry index
Example
ORACLE# acl-show
