session-agent > match-identifier
The match-identifier sub-element provides the parameters for the session-agents representing nodes behind Oracle Communications Session Border Controller to assist in the identification of the session-agents.
Parameters
- identifier-rule
- Configure with the name of a session-agent-id-rule
- match-value
- Enter a string value to be matched with the value in the SIP header for identifying a session agent.
The comparison between the match-value and the value of the SIP header parameter and is an exact and case-sensitive match.Path
session-agent is an element under the session-router path. The full path from the topmost ACLI prompt is: > match-identifier
This is a multiple instance configuration element.
