session-agent > rate-constraints
The rate-constraints subelement for the session-agent configuration element allows you to configure rate constraints for individual session agents, which can then be applied to the SIP interface where you want them used.
Parameters
- method
- Enter the SIP method name for the method you want to throttle
- Values:
- NOTIFY
- OPTIONS
- MESSAGE
- PUBLISH
- REGISTER
- Values:
- max-inbound-burst-rate
- For the SIP method you set in the method parameter, enter the number to restrict the inbound burst rate on the SIP interface where you apply these constraints.
- Default: 0
- Values: Min: 0 | Max: 999999999
- max-outbound-burst-rate
- For the SIP method you set in the method parameter, enter the number to restrict the outbound burst rate on the SIP interface where you apply these constraints.
- Default: 0
- max-inbound-sustain-rate
- For the SIP method you set in the method parameter, enter the number to restrict the inbound sustain rate on the SIP interface where you apply these constraints
- Default: 0
- max-outbound-sustain-rate
- For the SIP method you set in the method parameter, enter the number to restrict the outbound sustain rate on the SIP interface where you apply these constraints
- Default: 0
Path
rate-constraints is an element of the session-router path. The full path from the topmost ALCI prompt is:rate-constraints.
