snmp-view-entry
The snmp-view-entry element is used by an SNMPv3 agent to include or exclude access to single or multiple MIB OID nodes for an SNMP view name. An SNMP view is a mapping between SNMP scalar and tabular objects and the access rights available for this SNMP view. Scalar objects define a single object instance and tabular objects define multiple related object instances grouped in MIB tables.
This element must be configured in order for an SNMPv3 agent to work.Parameters
- view-name
- Use this required
parameter to enter the SNMP view name.
- Default: none
- Values: <string> that is 1 to 24 characters.
For example:- view-name AcmeSbcMibView
- included-sub-trees
- Use this required parameter to include access rights for object
Identifier (OID) nodes.
- Values: <OID>
number separated by a dot (.) in which each subsequent OID (from 0 to 32) is a
sub-identifier. You can enter multiple OIDs by separating them with a space.
For example:
- included-sub-trees 1.3.6.1.2, 1.3.6.1.4.1.9148
- Values: <OID>
- excluded-sub-trees
- Use this optional parameter to exclude access rights for OID
nodes.
- Values: <OID>
For example:
- excluded-sub-trees 1.3.6.1.4.1.9148.3.3
- Values: <OID>
Path
snmp-view-entry is an element under the system path. The full path from the topmost ACLI prompt is:
