snmp-user-entry
The required snmp-user-entry element is used to create an identity for one or more SNMPv3 users, their security level, passwords for secure authentication and privacy. This element provides a way to identify a user, protect the user from a different SNMP agent that uses message capture and replay, and protect the user from a network traffic source that uses an incorrect password or security level.
Parameters
- name
- Enter the name of
the user authorized for retrieving SNMPv3 information.
- Default: none
- Values: <user name string> that is 1 to 24 characters.
- auth-protocol
- Use this required parameter to enter the HMAC-SHA2-256 or
HMAC-SHA2-512 authentication protocol.
- Default: sha512
- Values: none | sha256 | sha512
- priv-protocol
- Use this required parameter to enter the AES or CBC-DES privacy
protocol.
- Default: aes128
- Values: none | aes128
- auth-password
- Enter the
authorization password for this user. This value is obscured when displayed at
the ACLI.
- Default: none
- Values: <password-string> that is 6 to 64 characters.
- priv-password
- Enter the privacy
password for this user. This value is obscured when displayed at the ACLI.
- Default: none
- trap-filter-level
- Use this optional parameter to allow this user to view traps
based on their severity level.
- ALL—A user can view all trap conditions.
- Minor—A user can view trap error conditions that exist on a device.
- Major—A user can view trap critical conditions that exist on a device.
- Critical—A user can view trap conditions that require an immediate action for a device.
- None—(Default) A user cannot view trap conditions.
- address-list
- Enter the required address list name(s) for this user, which must
match an
address-name
parameter that you specified when you configured the
snmp-address-entry
element.
- Default: none
- Values: <address-string> that is 1 to 24 characters. You can specify multiple address list names by separating them with a comma.
Path
snmp-community is an element under the system path. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
