FQDN-resolved Session Agent Statistics SNMP Retrieval
When FQDN-resolved Session Agent Statistics are enabled, you can retrieve each IP target's session agent statistics via SNMP.
The apSipAgentTable returns a list of configured sessions agent with an index corresponding and configuration name. The mapping of index to configuration name is persistent across system reboot.
The index of the additional entries that correspond to the individual IP targets are identified by starting at 10000000. Because the IP targets that are retrieved from the DNS server may change on any DNS query, they are not persistent across a reboot. An snmpwalk query on asSIPAgentTable appears as:
SNMPv2-SMI::enterprises.9148.3.15.1.2.3.1.2.36 = STRING: "sa1.dg.com" SNMPv2-SMI::enterprises.9148.3.15.1.2.3.1.210000000 = STRING: "sa1.dg.com#192.168.26.2" SNMPv2-SMI::enterprises.9148.3.15.1.2.3.1.210000001 = STRING: "sa1.dg.com#192.168.26.3"
The following snmpwalk query on asSipSessionAgentStatsTable appears as:
SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.1.36 = INTEGER: 36 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.1.10000000 = INTEGER: 1000000 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.1.10000001 = INTEGER: 1000001 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.2.36 = STRING: "sa1.dg.com" SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.2.10000000 = STRING: "sa1.dg.com#192.168.26.2" SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.2.10000001 = STRING: "sa1.dg.com#192.168.26.3" SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.3.36 = INTEGER: 1 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.3.10000000 = INTEGER: 1 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.3.1000001 = INTEGER: 1 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.4.36 = Gauge32: 0 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.4.10000000 = Gauge32: 0 SNMPv2-SMI::enterprises.9148.3.2.1.2.2.1.4.10000001 = Gauge32: 0 FQDN-resolved Session Agent Statistics SNMP Traps
The apSysMgmtSAStatusChangeTrap trap is generated when a session agent's individual IP target changes state.
