Transcoding Load Objects for SNMP Retrieval
Transcoding load and resource utilization counters are available in the ap-codec.mib file. There are three groups which are presented, currently active transcoded session per licensed codec, maximum licensed capacity per licensed codec, load per DSP.
Active Transcoded Sessions
The apCodecTranscodingResourceUtilMIBObjects, OID:
		  1.3.6.1.4.1.9148.3.7.2.5 presents the current number of active sessions of
		  licensed codecs. This is found in
		  ap-codec.mib.
This object corresponds to show xcode load ACLI Command and xcode-codec-util HDR group.
DSP Load of Transcoding Module
ap-codec.mib:
		- TCU identifier
- TCM Identifier
- DSP Identifier
- Session Count for that DSP
- Current load for that DSP
- Peak load for that DSP
- DSP Overload state
If the DSP is neither Active nor Overloaded then that DSP will not appear as an instance of the table.This object corresponds to show xcode load -detail ACLI Command and xcode-tcm-util HDR group.
Licensed Codec Capacity
MIB Objects that present maximum capacity of licensed codecs are found
		  in
		  ap-license.mib, as part of the apLicenseEntry,
		  OID:1.3.6.1.4.1.9148.3.5.1.1.1
