Rx Policy Server Objects for SNMP Retrieval
Rx policy server counters are available from the
apDiamRxPolicyServerStatsTable. The OID prefix is
1.3.6.1.4.1.9148.3.13.1.1.2.3
which is found in the
ap-diameter.mib file.
The apDiamRxPolicyServerStatsTable contains numerous policy server statistics and corresponds to the show policy-server stats command and the ext-Rx-policy-server HDR group.
When system boots, every policy server object is assigned id which persists across subsequent reboots. If policy server objects are deleted, the id does not change. This is similar to how session agent objects have persistent indexing.
