SRVCC Objects for SNMP Retrieval
SRVCC counters are available from the
apSipSRVCCStatsobjects. The OID prefix is
1.3.6.1.4.1.9148.3.15.1.1.3 which is found in the
ap-sip.mib file. The These counters are the same as
that reported by the
show sipd
srvcc command.
The apSipSRVCCStatsobjects contains numerous SRVCC statistics and corresponds to the show sipd srvcc command and the sip-srvcc HDR group.
