Enabling Administrative Trap Types
Use this task to enable traps for certain Oracle Communications Session Border Controller (OCSBC) events that are reported to a network management system. These settings are applicable to both SNMPv1v2 and SNMPv3 deployments. The OCSBC does not require you to enable traps other than those in the following steps.
 Access the
			 system-config configuration element.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# system-config ORACLE(system-config)#
Type
			 select to begin editing the
			 system-config object.
ORACLE(system-config)# select ORACLE(system-config)#
enable-snmp-monitor-traps—When
			 this parameter is enabled, the
			 Oracle Communications Session Border Controller generates traps with unique trap-IDs for each syslog
			 event. If this parameter is disabled , a single trap-ID is used for all events,
			 with different values in the description string. The default is
			 disabled. The valid
			 values are:
enabled | disabled
enable-snmp-auth-traps—Set
			 whether the SNMP authentication traps are enabled. If an SNMP request fails
			 authentication because of an IPv4 address and SNMP community mismatch, the SNMP
			 request will be rejected. This field determines if an SNMP trap will be sent in
			 response to the authentication failure. The default is
			 disabled. Valid
			 values for this parameter are:
enabled | disabled
enable-env-monitor-traps—Set
			 whether or not the SNMP environment monitor traps are enabled. Environment
			 traps include main board PROM temperature, CPU voltage, power supplies, fan
			 speeds, etc. The default is
			 disabled. Valid
enabled | disabled
enable-snmp-syslog-notify—Set
			 whether SNMP traps are sent when the system generates an alarm message. The
			 SNMP agent sends a trap when an alarm is generated if the following conditions
			 are met:
SNMP is enabled.
This field is enabled.
The syslog severity level is equal to or greater than the severity level configured in the SNMP Syslog Level field. The default is disabled. Valid values are:
enabled | disabled
snmp-syslog-his-table-length—Set
			 the length of the syslog trap history table. When a syslog message that meets
			 the SNMP syslog level field criteria is generated and SNMP is enabled, the SNMP
			 agent adds that message to a history table. This parameter indicates the number
			 of entries the table can contain. The default is
			 1. The valid range
			 is:
Minimum—1
Maximum—500 Once the last table entry is filled, the oldest entry will be overwritten with a new entry.
snmp-syslog-level—Set
			 the log severity level threshold that will cause the syslog trap to be sent to
			 an NMS. When this criteria is met and the appropriate SNMP trap is sent, an
			 entry is written to the SNMP Syslog History Table. The default is
			 warning. The
			 following are valid values:
emergency | critical | major | minor | warning | notice | info | trace | debug | detail
