Enabling Media Supervision Traps
The Oracle Communications Session Border Controller (OCSBC) sends the following media supervision trap when functioning as a border gateway and the media supervision timer expires:
apSysMgmtMediaSupervisionTimerExpTrap    NOTIFICATION-TYPE
      OBJECTS          { apSysMgmtCallId }
      STATUS            current
      DESCRIPTION
            " The trap will be generated when a media supervision timer
            has expired.  This behavior is disabled by default but may
            be enabled by changing the 'media-supervision-traps'
            parameter of the 'media-manager' configuration element.  The
            included object is the call identifer for the call which had
            the timer expire."
      ::= { apSystemManagementMonitors 34 }
The system does not send this trap when functioning as an integrated OCSBC.The media supervision trap is disabled by default. You can enable the trap by changing the media-supervision-traps parameter to enabled in the media-manager configuration element.
