apH323 Traps (ap-h323.mib)
The following traps
are found in
ap-env-h323.mib. They
are used generally for reporting on environmental changes.
| Trap | Description |
| apH323StackMaxCallThresholdTrap:
1.3.6.1.4.1.9148.3.10.3.0.1 |
Generated when the number of H.323 calls increases the percentage of the max calls threshold. |
| apH323StackMaxCallThresholdClearTrap:
1.3.6.1.4.1.9148.3.10.3.0.2 |
Generated when the number of H.323 calls decreases to below the lowest max calls threshold. |
