apEnvMon Traps (ap-env-monitor.mib)
The following traps
		are found in
		ap-env-monitor.mib.
		They are used generally for reporting on environmental changes.
| Trap | Description |
| apEnvMonI2CFailNotification: 1.3.6.1.4.1.9148.3.3.4.0.1 | Sent when the Inter-IC bus (I2C) state changes from normal (1) to not functioning (7). |
| apEnvMonPortChangeNotification: 1.3.6.1.4.1.9148.3.3.4.0.5 | For the AP4500 only. Generated if a physical port is inserted/present or removed/not present. |
| apEnvMonStatusChangeNotification: 1.3.6.1.4.1.9148.3.3.4.0.2 | Sent when any entry of any environment monitor table changes in the state of a device being monitored. To receive this trap, you need to set the system config’s enable- env- monitor- table value to enabled. |
