Acme Packet Codec and Transcoding MIB (ap-codec.mib)
The following table describes the SNMP GET query names for the Codec and Transcoding MIB (ap-codec.mib). The apCodecMIBObjects object has the OID 1.3.6.1.4.1.9148.3.7.1. The apCodecRealmStatsTable object has the OID 1.3.6.1.4.1.9148.3.7.1.1. The apCodecRealmStatsEntry object has the OID 1.3.6.1.4.1.9148.3.7.1.1.1.
apCodecMIBObjects
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.7.1.1.1 + | Description |
| apCodecRealmCountOther | .1 | Count of the SDP media streams received in the realm which negotiated to a codec not defined in this table. |
| apCodecRealmCountPCMU | .2 | Count of SDP media streams received in the realm which negotiated to the PCMU codec. |
| apCodecRealmCountPCMA | .3 | Count of SDP media streams received in the realm which negotiated to the PCMA codec. |
| apCodecRealmCountG722 | .4 | Count of SDP media streams received in the realm which negotiated to the G722 codec. |
| apCodecRealmCountG723 | .5 | Count of SDP media streams received in the realm which negotiated to the G723 codec. |
| apCodecRealmCountG726-16 | .6 | Count of SDP media streams received in the realm which negotiated to the G726-16 codec. |
| apCodecRealmCountG726-24 | .7 | Count of SDP media streams received in the realm which negotiated to the G726-24 codec. |
| apCodecRealmCountG726-32 | .8 | Count of SDP media streams received in the realm which negotiated to the G726-32 codec. |
| apCodecRealmCountG726-40 | .9 | Count of SDP media streams received in the realm which negotiated to the G726-40 codec. |
| apCodecRealmCountG728 | .10 | Count of SDP media streams received in the realm which negotiated to the G728 codec. |
| apCodecRealmCountG729 | .11 | Count of SDP media streams received in the realm which negotiated to the G729 codec. |
| apCodecRealmCountGSM | .12 | Count of SDP media streams received in the realm which negotiated to the GSM codec. |
| apCodecRealmCountILBC | .13 | Count of SDP media streams received in the realm which negotiated to the iLBC codec. |
| apCodecRealmCountAMR | .14 | Count of SDP media streams received in the realm which negotiated to the AMR codec. |
| apCodecRealmCountEVRC | .15 | Count of SDP media streams received in the realm which negotiated to the EVRC codec. |
| apCodecRealmCountH261 | .16 | Count of SDP media streams received in the realm which negotiated to the H261 codec. |
| apCodecRealmCountH263 | .17 | Count of SDP media streams received in the realm which negotiated to the H.263 codec. |
| apCodecRealmCountT38 | .18 | Count of SDP media streams received in the realm which negotiated to the T.38 codec. |
| apCodecRealmCountAMRWB | .19 | Count of SDP media streams received in the realm which negotiated to the AMR-WB codec. |
| apCodecRealmCountEVRC0 | .20 | Count of SDP media streams received in the realm which negotiated to the EVRC0 codec. |
| apCodecRealmCountEVRC1 | .21 | Count of SDP media streams received in the realm which negotiated to the EVRC1 codec. |
| apCodecRealmCountEVRCB | .22 | Count of SDP media streams received in the realm which negotiated to the EVRCB codec. |
| apCodecRealmCountEVRCB0 | .23 | Count of SDP media streams received in the realm which negotiated to the EVRCB0 codec. |
| apCodecRealmCountEVRCB1 | .24 | Count of SDP media streams received in the realm which negotiated to the EVRCB1 codec. |
| apCodecRealmCountOpus | .25 | Count of SDP media streams received in the realm which negotiated to the Opus codec. |
| apCodecRealmCountSILK | .26 | Count of SDP media streams received in the realm which negotiated to the SILK codec. |
| apCodecRealmCountT140 | .27 | Count of SDP media streams received in the realm which negotiated to the T.140 codec. |
| apCodecRealmCountBAUDOT | .28 | Count of SDP media streams received in the realm which negotiated to the BAUDOT codec. |
| apCodecRealmCountH264 | .29 | Count of SDP media streams received in the realm which negotiated to the H.264 codec. |
| apCodecRealmCountEVRCNW | .30 | The count of SDP media streams received in the realm which negotiated to the EVRCNW codec. |
| apCodecRealmCountEVRCNW0 | .31 | The count of SDP media streams received in the realm which negotiated to the EVRCNW0 codec. |
| apCodecRealmCountEVRCNW1 | .32 | The count of SDP media streams received in the realm which negotiated to the EVRCNW1 codec |
| apCodecRealmCountEVS | .33 | The count of SDP media streams received in the realm which negotiated to the EVS codec. |
apTranscodingMIBObjects
The apTranscodingMIBObjects object has the OID 1.3.6.1.4.1.9148.3.7.2. The apCodecTranscodingRealmStatsTable object has the OID 1.3.6.1.4.1.9148.3.7.2.1. The apTranscodingRealmStatsEntry object has the OID 1.3.6.1.4.1.9148.3.7.2.1.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.7.2.1.1 + | Description |
| apCodecRealmSessionsTransparent | .1 | Number of sessions in the realm that did not use any DSP resources for transcoding or transrating. |
| apCodecRealmSessionsTransrated | .2 | Number of sessions in the realm that had a common codec but used DSP resources to modify packetization rate. |
| apCodecRealmSessionsTranscoded | .3 | Number of sessions in the realm that had used DSP resources to transcode between codecs. |
apCodecTranscodingResourceMIBObjects
The apCodecTranscodingResourceMIBObjects object has the OID 1.3.6.1.4.1.9148.3.7.2.2. It contains 5 OIDS that return overall system transcoding counts and statistics.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.7.2.2 + | Description |
| apCodecTranscodingResourcesTotal | .1 | Total number of transcoding sessions available on the system. |
| apCodecTranscodingResourcesCurrent | .2 | Number of transcoding sessions currently in-use. |
| apCodecTranscodingResourcesHigh | .3 | Highest number of transcoding sessions simultaneously in-use since system reboot or manual statistic reset. |
| apCodecTranscodingInUsePercentCurrent | .4 | Transcoding sessions currently in-use as a percentage of total available sessions. |
| apCodecTranscodingInUsePercentHigh | .5 | Transcoding sessions simultaneously in-use since system reboot or manual statistic reset expressed as a percentage of total available sessions. |
apCodecPairStatsTable
This table, found in the ap-codec.mib, provides a listing of all unique codec pairs currently being transcoding and the session count of that pair currently in use. It conveys the same information displayed in the show xcode codecs command. Use the apCodecTable for correlation between Codec name (apCodecName) and Codec index (apCodecIndex) to define apCodecPairAIndex and apCodecPairBIndex. When Ptimes for call legs in the codec pair differ, they will be included as additional indices. When digit translation is active on the call and digit translation types differ across call legs, indication of which call leg uses which digit translation type is output as well. Use the ApCodecDigitTypes object for digit type value correlation.
| MIB Object | Object ID: 1.3.6.1.4.1.9148.3.7.2.4 + | Description |
| apCodecPairStatsEntry | .1 | Entry of this table. Note that the end point A is the one with smaller or equal apCodecIndex. |
| apCodecPairAIndex | .1.1 | The index of the first codec in the pair |
| apCodecPairBIndex | .1.2 | The index of the second codec in the pair |
| apCodecPairAPValue | .1.3 | The p value in the end point A. A value of zero indicates the value is not provided. |
| apCodecPairBPValue | .1.4 | The p value in the end point B. A value of zero indicates the value is not provided. |
| apCodecPairADigitType | .1.5 | The digit type index in the end point A. |
| apCodecPairBDigitType | .1.6 | The digit type index in the end point B. |
| apCodecPairTranscodingCurrent | .1.7 | The current number of transcoding sessions for this codec-pair since system reboot or manual statistic reset. |
| apCodecPairTranscodingHigh | .1.8 | The highest number of transcoding sessions in use for this codec-pair since system reboot or manual statistic reset. |
Transcoding Capacity in System Management MIB (ap-smgmt.mib)
The following VARBINDs are used in Transcoding related traps. They may not be polled and retrieved using an SNMP GET.
The apSysMgmtMIBObjects object has the OID 1.3.6.1.4.1.9148.3.2.1. The apSysMgmtGeneralObjects object has the OID 1.3.6.1.4.1.9148.3.2.1.1.
| SNMP Object Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.1 + | Description |
| apSysXCodeCapacity | .34 | Percentage of transcoding utilization. |
| apSysXCodeAMRCapacity | .35 | Percentage of licensed AMR transcoding sessions. |
| apSysXCodeAMRWBCapacity | .36 | Percentage of licensed AMR-WB transcoding sessions. |
| apSysXCodeEVRCCapacity | .39 | Percentage of licensed EVRC transcoding sessions. |
| apSysXCodeEVRCBCapacity | .40 | Percentage of licensed EVRCB transcoding sessions. |
| apSysAcpTlsEnabled | .41 | A value of TRUE indicates ACP over TLS connection is supported and enabled. A FALSE value indicates ACP over TLS connection is not enabled |
| apSysXCodeG729Capacity | .42 | The percentage of licensed G729 transcoding utilization |
| apSysXCodeOpusCapacity | .46 | The percentage of licensed Opus transcoding utilization (non pollable). |
| apSysXCodeSILKCapacity | .47 | The percentage of licensed SILK transcoding utilization (non pollable). |
