Acme Packet Diameter MIB (ap-diameter.mib)
The Diameter MIB (ap-diameter.mib) contains one table (apDiamClfErrorStatsTable: 1.3.6.1.4.1.9148.3.13.1.1.2.1) and 6 traps. There are numerous objects that are included within the traps, and these objects are not accessible from outside of the traps.
The apDiamClfErrorStatsTable lists Diameter Clf error status.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.13.1.1.2.1 + | Description |
| apDiamClfErrorStatsEntry | .1 | N/A |
| apDiamClfExtPolSvrIndex | .1.1 | An integer for the sole purpose of indexing the external policy servers. |
| apDiamClfExtPolSvrName | .1.2 | External policy server name |
| apDiamClfErrorsRecent | .1.3 | Number of diameter errors in recent period received on e2 interface with the CLF. |
| apDiamClfErrorsTotal | .1.4 | Total number of diameter errors in life time received on e2 interface with the CLF. |
| apDiamClfErrorsPerMax | .1.5 | PerMax count of diameter errors in life time received on e2 interface with the CLF. |
The following objects in the ap-diameter MIB are only available in the trap notifications:
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.13.1.2.1 + | Description |
| apDiamAcctSrvrHostName | .1 | The Diameter Accounting Server host name. |
| apDiamAcctSrvrIPPort | .2 | The Diameter Accounting Server IP address and port number: XX.XX.XX.XX:P |
| apDiamAcctSrvrOriginRealm | .3 | The Diameter Accounting Server Origin Realm. |
| apDiamAcctSrvrOriginHost | .4 | The Diameter Accounting Server Origin Host. |
| apDiamAcctSrvrTransportType | .5 | The Diameter Accounting Server Transport Type. |
| apAcctMsgQueueAvailCurrent | .6 | The current measured percentage value of space available |
| apAcctMsgQueueMinorThreshold | .7 | The current configured minor threshold value. |
| apAcctMsgQueueMajorThreshold | .8 | The current configured major threshold value. |
| apAcctMsgQueueCriticalThreshold | .9 | The current configured critical threshold value. |
| apDiameterResultCode | 10 | The Result-Code AVP (268) value RFC 3588, 7.1. Result-Code AVP |
