Acme Packet Software Inventory MIB (ap-swinventory.mib)
The following table describes the SNMP GET query names for the Software Inventory MIB (ap-swinventory.mib).
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.4.1.1.1.1 + | Description |
| apSwBootDescr | .2 | Description of the software image which may
				  consist of a filename, data and time this image was built or the unique
				  identifier of the software. For example: boot image: 10.0.1.12/sd201p3.gz for host address is 10.0.1.12, and image name is sd201p3.gz boot image: /tffs0/sd201p3.gz for boot from flash 0 and image name is sd201p3.gz boot loader: bank0:03/18/2005 10:58:25 for boot from bank 0, and version is March 18 2005, 10:58:25’. |
| apSwBootType | .3 | Type of software image. A value of 1 indicates a boot Image. A value of 2 indicates a bootloader image. |
| apSwBootStatus | .4 | Status of the software image. A value of 1 indicates an image that is currently being used. A value of 2 indicates a previously used image. |
The object apSwInventoryCfgObjects has the OID 1.3.6.1.4.1.9148.3.4.1.2.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.4.1.2 + | Description |
| apSwCfgCurrentVersion | .1 | Current version of the saved configuration. |
| apSwCfgRunningVersion | .2 | Current version of the running configuration. |
The object apSwCfgBackupEntry has the OID 1.3.6.1.4.1.9148.3.4.1.2.3.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.4.1.2.3.1 + | Description |
| apSwCfgBackupName | .2 | Description of the configuration filename, for example: p1604, 063004-cfg. |
