Acme Packet System Management MIB (ap-smgmt.mib)
The following table describes the SNMP GET query names for the System Management MIB (ap-smgmt.mib).
Note that the apSigRealmStats MIB is populated for realms on which H.323 and SIP are configured; this supports aggregate statistics for H.323 and SIP. A note like this one appears with the OID information shown in the table below.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.1 + | Description |
| apSysCPUUtil | .1 | Percentage of CPU utilization. This value reflects the mean CPU utilization for all cores on the system. For a system with 4 cores, the number reported here is (CPU0 + CPU1 + CPU2 + CPU3)/4. This value is updated very second. |
| apSysMemoryUtil | .2 | Percentage of memory utilization. |
| apSysHealthScore | .3 | System health percentage, with a system health percentage value of 100 (100%) being the healthiest. |
| apSysRedundancy | .4 | For HA pairs, information about
				  whether this SBC is active or standby. Possible values are: initial(1): system is at initial stage active(2): system is active standby(3): system is standby outOfService(4): system is out of service For a Standalone system, a value of (2) is returned. |
| apSysGlobalConSess | .5 | Total instant number of global concurrent sessions at the moment. |
| apSysGlobalCPS | .6 | System-wide global calls per second. This counter is calculated based on a sliding window of 100 seconds. |
| apSysNATCapacity | .7 | Percentage of NAT table in Content Addressable Memory (CAM) utilization. |
| apSysARPCapacity | .8 | Percentage of ARP table (in CAM) utilization. |
| apSysState | .9 | Current system state. Online denotes regular call processing and offline implies no call processing occurring but other administrative functions are available. |
| apSysLicenseCapacity | .10 | Percentage of licensed sessions currently in progress. |
| apSysSipStatsActiveLocalContacts | .11 | Number of currently cached registered contacts in the SBC. |
| apSysMgcpGWEndpoints | .12 | Not Supported. |
| apSysH323Registration | .13 | Number of H.323 registrations in the SBC. |
| apSysRegCacheLimit | .14 | Maximum number of contacts to be accepted into the registration cache. A value of 0 indicates no limit. |
| apSysApplicationCPULoadRate | .16 | This value reflects the load of the sipd application on the cores where the threads have been scheduled. Thus if there are two sipd threads running on individual cores, a and b, the number reported here is (CPUa + CPUb)/2. |
| apSysRejectedMessages | .18 | Number of messages rejected by the SBC due to matching criteria. |
| apSysSipEndptDemTrustToUntrust | .19 | Global counter for SIP endpoint demotion from trusted to untrusted. |
| apSysSipEndptDemUntrustToDeny | .20 | Global counter for SIP endpoint demotion from untrusted to deny. |
| apSysMgcpEndptDemTrustToUntrust | .21 | Not Supported. |
| apSysMgcpEndptDemUntrustToDeny | .22 | Not Supported. |
| apSysSipTotalCallsRejected | .25 | Global counter for SIP calls that are rejected by the SBC |
| apSysSipStatsActiveSubscriptions | .27 | An unsigned 32-bit integer that specifies the current global count of active SIP subscriptions. |
| apSysSipStatsPerMaxSubscriptions | .28 | An unsigned 32-bit integer that specifies the maximum global count of SIP subscriptions initiated during any 100 second period since the last SBC re-boot. |
| apSysSipStatsPerMaximumActiveSubscriptions | .29 | An unsigned 32-bit integer that specifies the maximum global count of active SIP subscriptions since the last SBC re-boot. |
| apSysSipStatsTotalSubscriptions | .30 | An unsigned 32-bit integer that specifies the global count of active SIP subscriptions since the last SBC r e-boot. |
| apSysMgmtH248MgcName | .31 | Not Supported. |
| apSysMgmtH248Realm | .32 | Not Supported. |
| apSysMgmtH248PortMapUsage | .33 | Not Supported. |
| apSysCPULoadAvgOneMinute | .43 | The percentage of CPU Load across all cores measured over 1 minute. |
| apSysCPULoadAvgFiveMinute | .44 | The percentage of CPU Load across all cores measured over 5 minutes. |
| apSysCPULoadAvgFiftnMinute | .45 | The percentage of CPU Load across all cores measured over 15 minutes. |
The apSysMgmtCPULoadAvgGroup object has the OID 1.3.6.1.4.1.9148.3.2.4.2.31, and is an object that monitors CPU Load Average across all CPU cores for 1, 5, and 15 minutes.
The apSysStorageSpaceTable object has the OID 1.3.6.1.4.1.9148.3.2.1.1.23, and the apSysStorageSpaceEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.1.23.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.1.23.1 + | Description |
| apSysVolumeIndex | .1 | Monotonically increasing integer for the purpose of indexing volumes. |
| apSysVolumeName | .2 | Name of the volume. |
| apSysVolumeTotalSpace | .3 | Total size of the volume in MB. |
| apSysVolumeAvailSpace | .4 | Total space available on the volume in KB. |
The apCombinedSessionAgentStatsEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.2.1.1.
This table object reflects statistics found in the show sipd agents ACLI command.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.2.1.1 + | Description |
| apCombinedStatsSessionAgentIndex | .1 | A monotonically increasing integer for the sole purpose of indexing session agents. When it reaches the maximum value the agent wraps the value back to 1. |
| apCombinedStatsSessionAgentHostname | .2 | The hostname of the session agent for which the following statistics are being calculated. |
| apCombinedStatsSessionAgentType | .3 | The type of the specified session agent, either SIP or H323. |
| apCombinedStatsCurrentActiveSessionsInbound | .4 | Number of current active inbound
				  sessions. This value is found on the ACLI at show sipd agents, "Inbound Active" column. |
| apCombinedStatsCurrentSessionRateInbound | .5 | Current inbound session rate in
				  CPS. This value is found on the ACLI at show sipd agents, "Inbound Rate" column. |
| apCombinedStatsCurrentActiveSessionsOutbound | .6 | Number of current active outbound
				  sessions. This value is found on the ACLI at show sipd agents, "Outbound Active" column. |
| apCombinedStatsCurrentSessionRateOutbound | .7 | Current outbound session rate in
				  CPS. This value is found on the ACLI at show sipd agents, "Outbound Rate" column. |
| apCombinedStatsTotalSessionsInbound | .8 | Total number of inbound sessions during the 100 second sliding window period. |
| apCombinedStatsTotalSessionsNotAdmittedInbound | .9 | Total number of non-bandwidth constraints that exceeded rejections on inbound sessions (for example, max-sessions, burst rate, etc.). |
| apCombinedStatsPeriodHighInbound | .10 | Highest number of concurrent inbound sessions during the period. |
| apCombinedStatsAverageRateInbound | .11 | Average rate of inbound sessions
				  during the 100 second sliding window period in CPS. This value is found on the ACLI at show sipd agents, "Inbound Rate" column. |
| apCombinedStatsTotalSessionsOutbound | .12 | Total number of outbound sessions during the 100 second sliding window period. |
| apCombinedStatsTotalSessionsNotAdmittedOutbound | .13 | Total number of non-bandwidth constraints that exceeded rejections on outbound sessions (for example, max-sessions, burst rate, etc.). |
| apCombinedStatsPeriodHighOutbound | .14 | Highest number of concurrent outbound sessions during the 100 second sliding window period. |
| apCombinedStatsAverageRateOutbound | .15 | Average rate of outbound sessions
				  during the 100 second sliding window period in CPS. This value is found on the ACLI at show sipd agents, "Outbound Rate" column. |
| apCombinedStatsMaxBurstRate | .16 | Maximum burst rate of traffic
				  measured during the 100 second sliding window period (combined inbound and
				  outbound). This value is found on the ACLI at show sipd agents, "Max Burst" counter. |
| apCombinedStatsPeriodSeizures | .17 | Total number of seizures during the 100 second sliding window period. |
| apCombinedStatsPeriodAnswers | .18 | Total number of answered sessions during the 100 second sliding window period. |
| apCombinedStatsPeriodASR | .19 | The answer-to-seizure ratio,
				  expressed as a percentage. For example, a value of 90 would represent 90%, or .90. |
| apCombinedStatsAverageLatency | .20 | Average observed one-way signalling latency during the period. |
| apCombinedStatsMaxLatency | .21 | Maximum observed one-way signalling latency during the 100 second sliding window period. |
| apCombinedStatsSessionAgentStatus | .22 | The current status of the specified session agent, which is expressed as INS, OOSnonresp, OOSconstraintsviolation, BecomingOOS, or ForcedOOS. |
The apSipSessionAgentStatsEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.2.2.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.2.2.1 + | Description |
| apSipSAStatsSessionAgentIndex | .1 | A monotonically increasing integer for the sole purpose of indexing session agents. When it reaches the maximum value the agent wraps the value back to 1. |
| apSipSAStatsSessionAgentHostname | .2 | The hostname of the session agent for which the following statistics are being calculated. |
| apSipSAStatsSessionAgentType | .3 | The type of the specified session agent, either SIP or H323. |
| apSipSAStatsCurrentActiveSessionsInbound | .4 | Number of current active inbound sessions. |
| apSipSAStatsCurrentSessionRateInbound | .5 | Current Inbound Session rate in CPS. |
| apSipSAStatsCurrentActiveSessionsOutbound | .6 | Number of current active outbound sessions. |
| apSipSAStatsCurrentSessionRateOutbound | .7 | Current outbound session rate in CPS. |
| apSipSAStatsTotalSessionsInbound | .8 | Total number of inbound sessions during the 100 second sliding window period. |
| apSipSAStatsTotalSessionsNotAdmittedInbound | .9 | Total number of inbound sessions rejected due to insufficient bandwidth. |
| apSipSAStatsPeriodHighInbound | .10 | Highest number of concurrent inbound sessions during the 100 second sliding window period. |
| apSipSAStatsAverageRateInbound | .11 | Average rate of inbound sessions during the 100 second sliding window period in CPS. |
| apSipSAStatsTotalSessionsOutbound | .12 | Total number of outbound sessions during the 100 second sliding window period. |
| apSipSAStatsTotalSessionsNotAdmittedOutbound | .13 | Total number of outbound sessions rejected because of insufficient bandwidth. |
| apSipSAStatsPeriodHighOutbound | .14 | Highest number of concurrent outbound sessions during the 100 second sliding window period. |
| apSipSAStatsAverageRateOutbound | .15 | Average rate of outbound sessions during the 100 second sliding window period in CPS. |
| apSipSAStatsMaxBurstRate | .16 | Maximum burst rate of traffic measured during the 100 second sliding window period (combined inbound and outbound). |
| apSipSAStatsPeriodSeizures | .17 | Total number of seizures during the 100 second sliding window period. |
| apSipSAStatsPeriodAnswers | .18 | Total number of answered sessions during the 100 second sliding window period. |
| apSipSAStatsPeriodASR | .19 | The answer-to-seizure ratio, expressed as a percentage.For example, a value of 90 would represent 90%, or .90. |
| apSipSAStatsAverageLatency | .20 | Average observed one-way signaling latency during the 100 second sliding window period. |
| apSipSAStatsMaxLatency | .21 | Maximum observed one-way signaling latency during the 100 second sliding window period. |
| apSipSAStatsSessionAgentStatus | .22 | The current status of the specified session agent, which is expressed as INS, OOSnonresp, OOSconstraintsviolation, BecomingOOS, or ForcedOOS. |
The apH323SessionAgentStatsTable object has the OID 1.3.6.1.4.1.9148.3.2.1.2.3, and the apH323SessionAgentStatsEntry has the OID 1.3.6.1.4.1.9148.3.2.1.2.3.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.2.3.1 + | Description |
| apH323SAStatsSessionAgentIndex | .1 | A monotonically increasing integer for the sole purpose of indexing session agents. When it reaches the maximum value the agent wraps the value back to 1. |
| apH323SAStatsSessionAgentHostname | .2 | The hostname of the session agent for which the following statistics are being calculated. |
| apH323SAStatsSessionAgentType | .3 | The type of the specified session agent, H323. |
| apH323SAStatsCurrentActiveSessionsInbound | .4 | Number of current active inbound sessions. |
| apH323SAStatsCurrentSessionRateInbound | .5 | Current Inbound Session rate in CPS. |
| apH323SAStatsCurrentActiveSessionsOutbound | .6 | Number of current active outbound sessions |
| apH323SAStatsCurrentSessionRateOutbound | .7 | Current outbound session rate in CPS |
| apH323SAStatsTotalSessionsInbound | .8 | Total Number of inbound sessions during the 100 second sliding window period. |
| apH323SAStatsTotalSessionsNotAdmittedInbound | .9 | Total number of inbound sessions rejected due to insufficient bandwidth. |
| apH323SAStatsPeriodHighInbound | .10 | Highest number of concurrent inbound sessions during the 100 second sliding window period. |
| apH323SAStatsAverageRateInbound | .11 | Average rate of inbound sessions during the 100 second sliding window period in CPS. |
| apH323SAStatsTotalSessionsOutbound | .12 | Total number of outbound sessions during the 100 second sliding window period. |
| apH323SAStatsTotalSessionsNotAdmittedOutbound | .13 | Total number of outbound sessions rejected because of insufficient bandwidth. |
| apH323SAStatsPeriodHighOutbound | .14 | Highest number of concurrent outbound sessions during the 100 second sliding window period. |
| apH323SAStatsAverageRateOutbound | .15 | Average rate of outbound sessions during the 100 second sliding window period in CPS. |
| apH323SAStatsMaxBurstRate | .16 | Maximum burst rate of traffic measured during the 100 second sliding window period (combined inbound and outbound). |
| apH323SAStatsPeriodSeizures | .17 | Total number of seizures during the 100 second sliding window period. |
| apH323SAStatsPeriodAnswers | .18 | Total number of answered sessions during the 100 second sliding window period. |
| apH323SAStatsPeriodASR | .19 | The answer-to-seizure ratio, expressed as a percentage. For example, a value of 90 would represent 90%, or .90. |
| apH323SAStatsAverageLatency | .20 | Average observed one-way signalling latency during the 100 second sliding window period. |
| apH323SAStatsMaxLatency | .21 | Maximum observed one-way signalling latency during the 100 second sliding window period |
| apH323SAStatsSessionAgentStatus | .22 | The current status of the specified session agent, which is expressed as INS, OOSnonresp, OOSconstraintsviolation, BecomingOOS, or ForcedOOS |
The apSigRealmStatsTable object has the OID 1.3.6.1.4.1.9148.3.2.1.2.4 and the apSigRealmStatsEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.2.4.1.
This table is populated for realms on which H.323 and SIP are configured; this supports aggregate statistics for H.323 and SIP.| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.2.4.1 + | Description |
| apSigRealmStatsRealmIndex | .1 | A monotonically increasing integer for the sole purpose of indexing realms. When it reaches the maximum value the agent wraps the value back to 1. |
| apSigRealmStatsRealmName | .2 | The name of the realm for which the following statistics are being calculated. |
| apSigRealmStatsCurrentActiveSessionsInbound | .3 | Number of current active inbound sessions. |
| apSigRealmStatsCurrentSessionRateInbound | .4 | Current inbound session rate in CPS. |
| apSigRealmStatsCurrentActiveSessionsOutbound | .5 | Number of current active outbound sessions. |
| apSigRealmStatsCurrentSessionRateOutbound | .6 | Current outbound session rate in CPS. |
| apSigRealmStatsTotalSessionsInbound | .7 | Total number of inbound sessions during the 100 second sliding window period. |
| apSigRealmStatsTotalSessionsNotAdmittedInbound | .8 | Total number of inbound sessions rejected because of insufficient bandwidth. |
| apSigRealmStatsPeriodHighInbound | .9 | Highest number of concurrent inbound sessions during the 100 second sliding window period. |
| apSigRealmStatsAverageRateInbound | .10 | Average rate of inbound sessions during the 100 second sliding window period in CPS. |
| apSigRealmStatsTotalSessionsOutbound | .11 | Total number of outbound sessions during the 100 second sliding window period. |
| apSigRealmStatsTotalSessionsNotAdmittedOutbound | .12 | Total number of outbound sessions rejected because of insufficient bandwidth. |
| apSigRealmStatsPeriodHighOutbound | .13 | Highest number of concurrent outbound sessions during the 100 second sliding window period. |
| apSigRealmStatsAverageRateOutbound | .14 | Average rate of outbound sessions during the 100 second sliding window period in CPS. |
| apSigRealmStatsMaxBurstRate | .15 | Maximum burst rate of traffic measured during the 100 second sliding window period (combined inbound and outbound). |
| apSigRealmStatsPeriodSeizures | .16 | Total number of seizures during the 100 second sliding window period. |
| apSigRealmStatsPeriodAnswers | .17 | Total number of answered sessions during the 100 second sliding window period. |
| apSigRealmStatsPeriodASR | .18 | The answer-to-seizure ratio, expressed as a percentage. For example, a value of 90 would represent 90%, or .90. |
| apSigRealmStatsAverageLatency (not supported) | .19 | Average observed one-way signaling latency in milliseconds during the period. |
| apSigRealmStatsMaxLatency (not supported) | .20 | Maximum observed one-way signaling latency in milliseconds during the period. |
| apSigRealmStatsMinutesLeft | .21 | Number of monthly-minutes left in the pool per calendar year for a given realm. |
| apSigRealmStatsMinutesReject | .22 | Peg counts of the number of calls rejected because the monthly-minutes constraints are exceeded. |
| apSigRealmStatsShortSessions | .23 | Lifetime number of sessions whose duration was less than the configured short session durations. |
| apSigRealmStatsAverageQoSRFactor | .24 | Average QoS factor observed during the period. |
| apSigRealmStatsMaximumQoSFactor | .25 | Maximum QoS factor observed during the period. |
| apSigRealmStatsCurrentMajorRFactorExceeded | .26 | Peg counts of the number of times the major Rfactor threshold was exceeded during the period. |
| apSigRealmStatsTotalMajorRFactorExceeded | .27 | Peg counts of the number of times the major Rfactor threshold was exceeded during the lifetime. |
| apSigRealmStatsCurrentCriticalRFactorExceeded | .28 | Peg counts of the number of times the critical Rfactor threshold was exceeded during the period. |
| apSigRealmStatsTotalCriticalRfactorExceeded | .29 | Peg counts of the number of times the critical Rfactor threshold was exceeded during the lifetime. |
| apSigRealmStatsRealmStatus | .30 | Current status of the specified realm, which is expressed as INS, constraintviolation, or callLoadReduction. |
| apSigRealmStatsActiveLocalContacts | .31 | An unsigned 32-bit integer that specifies the current domain count of active SIP registrations. |
| apSigRealmStatsActiveSubscriptions | .32 | Number of active subscriptions for the given realm. |
| apSigRealmStatsPerMaxSubscriptions | .33 | Lifetime PerMax subscriptions count for the given realm. |
| apSigRealmStatsMaximumActiveSubscriptions | .34 | Count of lifetime maximum active subscriptions for the given realm. |
| apSigRealmStatsTotalSubscriptions | .35 | Count of lifetime total subscriptions for the system. |
The apSysMgmtNetMgmtCtrlObjects object has the OID 1.3.6.1.4.1.9148.3.2.1.3, the apNetMgmtCtrlStatsTable object has the OID 1.3.6.1.4.1.9148.3.2.1.3.1, and the apNetMgmtCtrlStatsEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.3.1.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.3.1.1 + | Description |
| apNetMgmtCtrlStatsName | .1 | Name of the network management control (NMC) the for which statistics are being calculated. |
| apNetMgmtCtrlStatsType | .2 | Type of specified NMC: gap-rate, gap-percent, or priority. |
| apNetMgmtCtrlStatsIncomingTotal | .3 | Total number of incoming calls matching a destination identifier of the NMC. |
| apNetMgmtCtrlStatsRejectedTotal | .4 | Number of apNetMgmtCtrlStatsIncomingTotal that are rejected. |
| apNetMgmtCtrlStatsStatsDivertedTotal | .5 | Number of apNetMgmtCtrlStatsIncomingTotal that are diverted. |
| apNetMgmtCtrlStatsStatsIncomingCurrent | .6 | Number of incoming calls during the current period that match a destination identifier |
| apNetMgmtCtrlStatsStatsRejectedCurrent | .7 | Number of apNetMgmtCtrlStatsIncomingCurrent that are rejected. |
| apNetMgmtCtrlStatsStatsDivertedCurrent | .8 | Number of apNetMgmtCtrlStatsIncomingCurrent that are diverted. |
| apNetMgmtCtrlStatsIncomingPeriodMax | .9 | Maximum number of incoming calls during a period that match a destination identifier of the NMC. |
| apNetMgmtCtrlStatsStatsRejectedPeriodMax | .10 | Number of apNetMgmtCtrlStatsIncomingPeriodMax that are rejected. |
| apNetMgmtCtrlStatsStatsDivertedPeriodMax | .11 | Number of apNetMgmtCtrlStatsIncomingPeriodMax that are diverted. |
| apNetMgmtCtrlStatsState | .12 | The state of the specified network management control, which can be disabled or enabled |
The apSysMgmtMIBENUMServerStatusObjects object has the OID 1.3.6.1.4.1.9148.3.2.1.4, the apENUMServerStatusTable object has the OID 1.3.6.1.4.1.9148.3.2.1.4.1, and the apENUMServerStatusEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.4.1.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.4.1.1 + | Description |
| apENUMConfigname | .1 | Name of the ENUM configuration element that contains this ENUM server. |
| apENUMServerIpAddress | .2 | IP address of this ENUM server. |
| apENUMServerStatus | .3 | Status of this ENUM server. |
The apSysMgmtMIBNSEPStatsObjects object has the OID 1.3.6.1.4.1.9148.3.2.1.5.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.5 + | Description |
| apNSEPStatsCurentActiveSessionsInbound | .1 | Number of currently active inbound NSEP sessions. |
| apNSEPStatsTotalSessionsInbound | .2 | Total number of inbound NSEP sessions during lifetime. |
| apNSEPStatsPeriodHighInbound | .3 | Highest number of concurrent inbound NSEP sessions during the period. |
| apNSEPStatsPeriod | .4 | The period for which all statistics are collected (in seconds). (Currently a non-configurable value of 30 minutes.) |
The apNSEPStatsRPHTable object has the OID 1.3.6.1.4.1.9148.3.2.1.5.5, and the apNSEPStatsRPHEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.5.5.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.5.5.1 + | Description |
| apNSEPStatsRPHValue | .1 | The specific RPH value used for indexing (namespace.rpriority). |
| apNSEPStatsRPHCurrentActiveSessionsInbound | .2 | Number of current active inbound NSEP sessions for this specific RPH value. |
| apNSEPStatsRPHTotalSessionsInbound | .3 | Total number of inbound NSEP sessions for this specific RPH value during lifetime. |
| apNSEPStatsRPHPeriodHighInbound | .4 | Highest number of concurrent inbound NSEP sessions during the period for this specific RPH value. |
| apNSEPStatsRPHTotalSessionsNotAdmittedInbound | .5 | Total number of inbound NSEP sessions rejected for this specific RPH value during lifetime. |
| apNSEPStatsRPHCurrentActiveSessionsOutbound | .6 | Number of current active outbound NSEP sessions for this specific RPH value. |
| apNSEPStatsRPHTotalSessionsOutbound | .7 | Total number of outbound NSEP sessions for this specific RPH value during lifetime. |
| apNSEPStatsRPHPeriodHighOutbound | .8 | Highest number of concurrent outbound NSEP sessions during the period for this specific RPH value. |
| apNSEPStatsRPHTotalSessionsNotAdmittedOutbound | .9 | Total number of outbound NSEP sessions rejected for this specific RPH value during lifetime |
The apLDAPServerStatusTable object has the OID 1.3.6.1.4.1.9148.3.2.1.6.1, and the apLDAPServerStatusEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.6.1.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.6.1.1 + | Description |
| apLDAPConfigName | .1 | Name of the LDAP configuration element that contains this LDAP server. |
| apLDAPServerIPAddress | .2 | IP address of this LDAP server. |
| apLDAPServerStatus | .3 | Status of this LDAP server. |
The apSysMgmtTrapTable object has the OID 1.3.6.1.4.1.9148.3.2.1.7.1, and the apSysMgmtTrapTableEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.7.1.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.7.1.1 + | Description |
| apTrapTableSystemTime | .1 | System time of the session border controller. |
| apTrapTableInstanceIndex | .2 | Instance index of the trap ID incremented with a resolution of a second. |
| apTrapTableNumVariables | .3 | Number of informarion encoded in the trap. |
| apTrapTableSysUptime | .4 | SNMP sysUpTime when the trap was generated. |
| apTrapTableTrapID | .5 | Trap ID assoicated with the fault condition. |
The apSysMgmtTrapInformationTable object has the OID 1.3.6.1.4.1.9148.3.2.1.7.2, and the apSysMgmtTrapInformationTableEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.7.2.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.7.2.1 + | Description |
| apTrapInformationTableDataIndex | .1 | Index of the information encoded in the trap. |
| apTrapInformationTableDataType | .2 | SNMP type enumerated encoded in the
				  trap. snmpTypeInteger is the size of integer snmpTypeObjectIpAddress is an octet string of length 4 |
| apTrapInformationTableDataLength | .3 | Octet length of the information encoded in the trap. |
| apTrapInformationTableDataOctets | .4 | Information represented in octets: snmpTypeInteger, snmpTypeObjectCounter32, snmpTypeObjectGauge, snmpTypeObjectOpaque, and snmpUnsignedInteger32 are 4 octets long snmpType counter is 8 octets long snmpTypeObjectIpAddress, snmpTypeObjectNSAPAddress are 4 octets long Data is aligned in network order. |
The apSysMgmtInterfaceObjects object has the OID 1.3.6.1.4.1.9148.3.2.1.8, the apSysMgmtPhyUtilTable object has the OID 1.3.6.1.4.1.9148.3.2.1.8.1, and the apSysMgmtPhyUtilTableEntry object has the OID 1.3.6.1.4.1.9148.3.2.1.8.1.1
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.2.1.8.1.1 + | Description |
| apPhyUtilTableRxUtil | .1 | RX network utilization of the physical port measured over a one second period. |
| apPhyUtilTableTxUtil | .2 | TX network utilization of the physical port measured over a one second period |
Notes on ENUM Server Names
Note that the characters of the name are given in the ASCII values because of SNMP’s restrictions. This representation affects the order in which entries in the table appear. Entries are listed:
- By the length of their names
- Then by a comparison of the characters they contain; this comparison is not limited to alphabetical order in that uppercase letter precede lowercase characters
- Last, by the IP address of the server for that entry
Take, for example, the case where there are three ENUM configurations:
- aaa, with servers 1.1.1.1 and 1.1.1.2
- BBB, with servers 3.3.3.3 and 3.3.3.2
- cc, with server 2.2.2.2
The entries would appear in the following order, with the following instance IDs:
- cc 2.2.2.2 would appear first because cc is the shortest name), and would be represented by the instance ID: … .2.99.99.2.2.2.2
- BBB entries would be next, sorted by IP address, because “BBB” is considered less than aaa, and would be represented by the instance IDs: … .3.66.66.66.3.3.3.2 and … .3.66.66.66.3.3.3.3
- aaa entries would appear last, represented by the instance IDs: ... .3.97.97.97.1.1.1.1 and ... .3.97.97.97.1.1.1.2
