About the Logs
When you configure persistent protocol tracing, you affect the following types of logs.
Enabling logs can have an impact on Oracle Communications Session Border Controller performance.Process Logs
Events are logged to a process log flow from tasks and are specific to a single process running on the Oracle Communications Session Border Controller. By default they are placed into individual files associated with each process with the following name format:
log.<taskname>
By setting the new log-filter parameter, you can have the logs sent to a remote log server (if configured). If you set log-filter to logs or all, the logs are sent to the log server. Otherwise, the logs are still captured at the level the process-log-level parameter is set to, but the results are stored on the Oracle Communications Session Border Controller’s local storage.
