Persistent Protocol Tracing Configuration
Before you configure persistent protocol tracing, ensure you have configured the process logs by setting the system configuration’s process-log-ip parameter.
To configure persistent protocol tracing:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
system and press Enter to access the system-level configuration elements.
ORACLE(configure)# system
Type
system-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(system)# system-config ORACLE(system-config)#
call-trace—Set to
enabled to enable protocol message tracing for sipmsg.log for SIP. The default is
disabled. The valid values are:
enabled | disabled
internal-trace—Set to
enabled to enable internal ACP message tracing for all processes. The default is
enabled | disabled
log-filter—Choose the appropriate setting for how you want to send and/or store trace information and process logs. The valid values are:
none—No information will be sent or stored.
traces—Sends the trace information to both the log server; includes <name>.log files that contain information about the Oracle Communications Session Border Controller’s internal communication processes (<name> is the name of the internal process)
traces-fork—Sends the trace information to both the log server and also keeps it in local storage; includes <name>.log files that contain information about the Oracle Communications Session Border Controller’s internal communication processes (<name> is the name of the internal process)
logs—Sends the process logs to both the log server; includes log.* files, which are Oracle Communications Session Border Controller process logs
logs-fork—Sends the process logs to both the log server and also keeps it in local storage; includes log.* files, which are Oracle Communications Session Border Controller process logs
all—Sends all logs to the log servers that you configure
all-fork—Sends all logs to the log servers that you configure, and it also keeps the logs in local storage
- Save and activate your configuration.
