H.323 Protocol Performance
This section describes the different statistics you can access for monitoring H.323 protocol performance.
Viewing the H.323 Performance Statistics
Display the H.323 performance statistics by using the show h323d command. The main show h323d command executed without arguments indicates the date and time the current period began and displays session statistics, status statistics, and stack statistics for functioning H.323 processes.
For example:
acmepacket# show h323d
18:22:24-84
Session Stats -- Period -- -------- Lifetime -------
Active High Total Total PerMax High
Incoming Calls 135 176 1001 77258 785 196
Outgoing Calls 135 176 1001 77258 785 196
Connected Calls 135 172 977 74390 727 196
Incoming Channels 251 319 1953 148780 1454 358
Outgoing Channels 251 319 1953 148780 1454 358
Contexts 135 179 1001 77258 785 197
H323D Status Current Lifetime
Queued Messages 238 16000
TPKT Channels 542 4004
UDP Channels 0 0
Stack State Type Mode Registered Gatekeeper
external enabled H323 Gateway No
internal enabled H323 Gateway No
The following table lists the session statistics along with a brief description.
| Statistic | Description |
| Incoming Calls | Number of H.323 calls coming into the Oracle Communications Session Border Controller. |
| Outgoing Calls | Number of H.323 calls going out of the Oracle Communications Session Border Controller. |
| Connected Calls | Number of H.323 calls that are currently connected via the Oracle Communications Session Border Controller. |
| Incoming Channels | Number of incoming channels that have been established on the Oracle Communications Session Border Controller. |
| Outgoing Channels | Number of outgoing channels that have been established on the Oracle Communications Session Border Controller. |
| Contexts | Number of contexts (i.e., the number of calls traversing the Oracle Communications Session Border Controller) that have been established on the Oracle Communications Session Border Controller. |
About Status Statistics
The following table lists the current H.323 process status statistics along with a brief description:
| Queued Messages | Number of messages queued. |
| TPKT Channels | Number of Transport Packet (TPKT) channels open(ed). |
| UDP Channels | Number of User Datagram Protocol (UDP) channels open(ed). |
The show h323d status command shows the same information available when the show h323d command is executed without any arguments.About Stack Statistics
The stack statistics provide a summary of information about the H.323 stacks configured on the Oracle Communications Session Border Controller via the h323 stack. This information includes the following facts about each stack: its name, whether or not it is enabled, its type, its mode (either Gateway or Gatekeeper), and whether or not it is registered with a Gatekeeper.
Viewing Current Configuration
Display statistics for the H.323 configuration currently running on the Oracle Communications Session Border Controller by using the show h323d config command. Only information about the main configuration element is shown, not for any subelements.
ORACLE# show h323d config h323-config state enabled log-level INFO response-tmo 4 connect-tmo 32 rfc2833-payload 101 alternate-routing proxy codec-fallback disabled last-modified-date 2006-07-07 07:49:57
Viewing Stack Information
You can view statistics about the configured H.323 stacks.
Viewing a List of Stacks
Display the list of H.323 stacks (for example, configured instances of the h323 stack) that are currently configured by using the show h323d stacklist command.
ORACLE# show h323d stacklist H323-Stack List name internal name external ORACLE#
Viewing Stack Details
Display detailed information about the configured instances of H.323 stacks by using the show h323d stackconfig command.
ORACLE# show h323d stackconfig h323-stack name tester state disabled isgateway enabled realm-id test assoc-stack acme local-ip 172.30.1.150 max-calls 100 max-channels 10 registration-ttl 15 terminal-alias e164=17823484839 prefixes url=http://www.acmepacket.com ras-port 1030 auto-gk-discovery enabled multicast 172.30.1.150:11 gatekeeper 170.30.1.150:57 gk-identifier RS q931-port 1720 alternate-transport 173.30.1.150:15 q931-max-calls 200 h245-tunneling disabled fs-in-first-msg disabled call-start-fast enabled call-start-slow disabled media-profiles acme process-registration disabled allow-anonymous all proxy-mode H225 h245-stage connect q931-start-port 0 q931-number-ports 0 dynamic-start-port 0 dynamic-number-ports 0 rfc2833-mode transparent filename packet11 tcp-keepalive disabled last-modified-date 2006-07-07 08:39:01 ORACLE#
Viewing Specific Stacks
Display detailed information about the configured H.323 stack specified in the <stack name> argument by using the show h323d stackconfig <stack name> command.
ORACLE# show h323d stackconfig internal h323-stack name internal state enabled isgateway enabled realm-id acme assoc-stack packet local-ip 0.0.0.0 max-calls 200 max-channels 6 registration-ttl 120 terminal-alias url=http://www.acmepacket.com prefixes ipAddress=63.67.143.4:2000 ras-port 1719 auto-gk-discovery disabled multicast 0.0.0.0:0 gatekeeper 0.0.0.0:0 gk-identifier rs q931-port 1720 alternate-transport q931-max-calls 200 h245-tunneling disabled fs-in-first-msg disabled call-start-fast enabled call-start-slow disabled media-profiles sip process-registration disabled allow-anonymous all proxy-mode H225 h245-stage connect q931-start-port 0 q931-number-ports 0 dynamic-start-port 0 dynamic-number-ports 0 rfc2833-mode transparent filename ps tcp-keepalive disabled last-modified-date 2006-07-10 11:48:13 ORACLE#
Viewing Session Agent Stats
You can view statistics about the session agents.
Viewing a List of Session Agents
Display a list of session agents by using the show h323d agentlist command. For example:
ORACLE# show h323d agentlist H323-Session Agent List hostname 192.168.200.20 hostname 192.168.200.30 hostname 10.10.10.3
Display statistics about the session agent by using the show h323d agentstats command. For example:
ORACLE# show h323d agentstats 172.16.0.13 19:57:21-51 Session Agent 172.16.0.13(h323172) [In Service] -- Period -- -------- Lifetime -------- Active High Total Total PerMax High Inbound Sessions 0 0 0 0 0 0 Rate Exceeded - - 0 0 0 - Num Exceeded - - 0 0 0 - Reg Rate Exceeded - - 0 0 0 - Outbound Sessions 199 245 196 23583 164 256 Rate Exceeded - - 0 0 0 - Num Exceeded - - 0 0 0 - Reg Rate Exceeded - - 0 0 0 - Out of Service - - 0 0 0 - Trans Timeout 0 0 0 19 2 1 Requests Sent - - 2092 234608 1569 - Requests Complete - - 196 23563 164 - Seizure - - 196 23583 164 - Answer - - 199 23563 164 - ASR Exceeded - - 0 0 0 - Messages Received - - 2267 258308 1675 - Latency=0.011; max=0.045
The following table lists the statistics along with a brief description of each.
| Inbound | |
| Active | Number of active sessions sent to each session agent listed in the Session Agent column of this command’s output. |
| Rate | Average rate of session invitations (per second) sent to each session agent listed in the Session Agent column of this command’s output. |
| ConEx | Number of times that the constraints established in the constraints fields of the session-agent element have been exceeded. The constraints fields of the session-agent element include the following: max-sessions, max-outbound-sessions, max-burst-rate, max-sustain-rate, burst-rate-window, and sustain-rate-window. |
| Outbound | |
| Active | Number of active sessions sent from each session agent listed in the Session Agent column of this command’s output. |
| Rate | Average rate of session invitations (per second) sent from each session agent listed in the Session Agent column of this command’s output. |
| ConEx | Number of times that the constraints established in the constraints fields of the session-agent element have been exceeded. |
| Latency | |
| Avg | Average latency for packets traveling to and from each session agent listed in the Session Agent column of this command’s output. |
| Max | Maximum latency for packets traveling to and from each session agent listed in the Session Agent column of this command’s output. |
| Max Burst | Total number of session invitations sent to or received from the session agent within the amount of time configured in the burst-rate-window field of the session-agent element. |
Viewing Specific Session Agent Statistics
Display the activity for the particular H.323 session agent specified in the <agent> argument by using the show h323d agents <agent> command.
The following table lists the statistics and a brief description.
| Inbound Sessions | |
| Rate Exceeded | Number of times the session or burst rate was exceeded for inbound sessions. |
| Num Exceeded | Number of times the time constraints were exceeded for inbound sessions. |
| Outbound Sessions | |
| Rate Exceeded | Number of times the session or burst rate was exceeded for outbound sessions. |
| Num Exceeded | Number of times the time constraints were exceeded for outbound sessions. |
| Burst | Number of times the burst rate was exceeded for this session agent. |
| Out of Service | Number of times this session agent went out of service. |
| Trans Timeout | Number of transactions that timed out for this session agent. |
| Requests Sent | Number of messages sent via the session agent. |
| Requests Complete | Number of requests that have been completed for this session agent. |
| Messages Received | Number of messages received by this session agent. |
Viewing Session Agent Configurations
Display the configuration for all configured H.323 session agents by using the show h323d agentconfig command.
ORACLE(session-agent)# show h323d agentconfig session-agent hostname testhostname.com ip-address 192.168.200.13 port 5060 state enabled app-protocol SIP app-type H323-GW transport-method UDP realm-id h323192 description carriers allow-next-hop-lp enabled constraints disabled max-sessions 0 max-inbound-sessions 4 max-outbound-sessions 5 max-burst-rate 0 max-inbound-burst-rate 10 max-outbound-burst-rate 1 max-sustain-rate 0 max-inbound-sustain-rate 0 max-outbound-sustain-rate 0 min-seizures 5 min-asr 0 time-to-resume 0 ttr-no-response 0 in-service-period 0 burst-rate-window 0 sustain-rate-window 0 req-uri-carrier-mode None proxy-mode Redirect redirect-action loose-routing enabled send-media-session enabled response-map ping-method ping-interval 0 ping-in-service-response-codes out-service-response-codes media-profiles in-translationid out-translationid trust-me disabled request-uri-headers stop-recurse local-response-map ping-to-user-part ping-from-user-part li-trust-me disabled in-manipulationid out-manipulationid p-asserted-id trunk-group tgname1:tgcontext1 tgname2:tgcontext2 max-register-sustain-rate 0 early-media-allow invalidate-registrations disabled rfc2833-mode none rfc2833-payload 0 codec-policy last-modified-date 2007-03-29 17:15:50 task done
Viewing Session Agent by Hostname
The show h323d agentconfig <hostname> command displays detailed information about the configured session agent specified by its hostname in the <hostname> argument.
When displaying individual H.323 session agent configurations, remember that H.323 does not support DNS and therefore the hostname field values for H.323 session agents are IPv4 addresses.
Viewing Session Agent Group Stats
You can view statistics for session agent groups.
Listing Session Agent Groups
Display a list of the H.323 session agent groups by using the show h323d grouplist command.
ORACLE# show h323d grouplist H323-Session Agent Group List group-name sag1 ORACLE#
Display session information for the session agent groups by using the show h323d groupstats command. Session information is compiled by totalling the session agent statistics for all session agents that make up a particular session agent group.
While the show h323d groupstats command accesses the subcommands that are described in this section, the main show h323d groupstats command (when executed without arguments) displays a list of all session agent groups for the Oracle Communications Session Border Controller.
All of the categories for these statistics are the same as those used in the displays produced by the show h323d agent command.
ORACLE# show h323d groupstats 19:38:59-30 ---- Inbound ---- --- Outbound ---- -Latency- ---- Max ---- SAG Active Rate ConEx Active Rate ConEx Avg Max Burst In Out H323Group 0 0.0 0 0 0.0 0 0.0 0.0 0 0 0
Viewing Session Agent Details
You can list and show the statistics for the session agents that make up the session agent groups that are being reported. The -v (meaning verbose) executed with this command must be included to provide this level of detail.
ORACLE# show h323d groups -v SAG: SGTest 19:38:59-30 ---- Inbound ---- --- Outbound ---- -Latency- --- Max --- SAG Active Rate ConEx Active Rate ConEx Avg Max Burst In Out H323Group 0 0.0 0 0 0.0 0 0.0 0.0 0 0 0 SAG: SGTest 192.168.200.61 120 0.0 0 359 0.0 0 0.0 0.0 50 0 0 Totals: SGTest D 120 0.0 0 359 0.0 0 0.0 0.0 50 0 0 ORACLE#
Viewing Specific Session Group Statistics
Display statistics for the designated session agent group by using the show h323d groups <group name> command with the name of a specific session agent group.
ORACLE# show h323d groups testgroup 16:35:18-18 ---- Inbound ---- --- Outbound ---- -Latency- Max SAG Active Rate ConEx Active Rate ConEx Avg Max Burst testgroup 0 0.0 0 0 0.0 0 0.0 0.0 0 ORACLE#
If this command is carried out, but the name of an existing session agent group is not available, the system will display a messaging saying that the group statistics are not available.
ORACLE# show h323d groups test group statistics not available ORACLE#
Viewing all Configurations
Display the configuration for all configured H.323 session agent groups by using the show h323d groupconfig command.
acmepacket# show h323d groupconfig
session-group
group-name h323
description
state enabled
app-protocol H323
strategy Hunt
dest
172.16.0.13
1.1.1.1
trunk-group
last-modified-date 2006-07-11 19:12:22
Viewing Specific Session Agent Group Statistics
Display detailed information about the configured session agent group specified by its group name by using the show h323d agentconfig <group name> command. The group name is configured in the group-name field of the session-agent-group element in the <group name> argument.
ORACLE# show h323d groupconfig h323 session-group group-name h323 description state enabled app-protocol H323 strategy Hunt dest 172.16.0.13 1.1.1.1 trunk-group last-modified-date 2006-07-11 19:12:22
Viewing Stats for Each Configured Stack
Display information for each of the configured H.323 stacks by using the show h323d h323stats command.
ORACLE# show h323d h323stats STACK : h323172 H.225 : Sent 585622 Recd 764844 maxCPU 0 H245 : Msg 976289 Ack 1171626 Rej 0 Rel 0 RAS : Req 0 Ack 0 Rej 0 maxCPU 0 STACK : h323192 H.225 : Sent 586040 Recd 585622 maxCPU 0 H245 : Msg 976087 Ack 1171626 Rej 0 Rel 0 RAS : Req 0 Ack 0 Rej 0 maxCPU 0
The display identifies the H.323 stack by its name and then provides the data described in the following table.
| H.225 | Number of H.225 messages sent and received by this H.323 stack |
| H245 | Number of H.245 requests, acknowledgements, rejections, and releases sent and received by this H.323 stack |
| RAS | Number of RAS requests, acks, and rejects sent and received by this H.323 stack |
Viewing Statistics for Specific Stacks
Display detailed statistics for the H.323 stack specified in the <stack name> argument by using the show h323d h323stats <stack name> command. This information is displayed according to the following categories: H.225, H.245, and RAS.
acmepacket# show h323d h323stats h323172 STACK : h323172 H.225 STATISTICS MESSAGE TYPE SENT RECD Setup 200118 0 Call Proceeding 0 0 Alerting 0 200112 Connect 0 200109 Progress 0 0 Facility 0 0 Release Complete 199906 191628 Status 0 0 Status Inquiry 0 0 Notify 0 0 Info 0 0 H.245 STATISTICS (Total) MESSAGE TYPE MSG ACK REJ REL Master Slave 200110 400218 0 0 Terminal Capability 400218 400218 0 0 OpenLogical Channel 0 0 0 0 CloseLogical Channel 399812 399812 0 0 RAS STATISTICS FOR MESSAGES SENT MESSAGE TYPE REQ CON REJ GK Discovery 0 0 0 Registration 0 0 0 Unregistration 0 0 0 Admission 0 0 0 Location 0 0 0 Bandwidth 0 0 0 Disengage 0 0 0 Info 0 0 RAS STATISTICS FOR MESSAGES RECD MESSAGE TYPE REQ CON REJ GK Discovery 0 0 0 Registration 0 0 0 Unregistration 0 0 0 Admission 0 0 0 Location 0 0 0 Bandwidth 0 0 0 Disengage 0 0 0 Info 0 0 ORACLE#
The following table lists the statistics along with its type and a brief description.
| Statistic | Type | Description |
| H.225 STATISTICS | Statistics about the H.225. | |
| MESSAGE TYPE | Type of messages sent and received by this H.323 stack. | |
| SENT | For each type of message specified in the MESSAGE TYPE column, how many of the message types were sent by this H.323 stack. | |
| RECD | For each type of message specified in the MESSAGE TYPE column, this statistic shows how many of the message types were received by this H.323 stack. | |
| H.245 STATISTICS Total | Statistics about the H.245 | |
| MESSAGE TYPE | Type of H.245 messages sent and received by this H.323 stack. | |
| MSG | For each type of H.245 message specified in the MESSAGE TYPE column, this statistic shows how many message requests were sent and received by this H.323 stack. | |
| ACK | For each type of H.245 message specified in the MESSAGE TYPE column, this statistic shows how many acknowledgements were sent and received by this H.323 stack. | |
| REJ | For each type of H.245 message specified in the MESSAGE TYPE column, this statistic shows how many rejections were sent and received by this H.323 stack. | |
| REL | For each type of H.245 message specified in the MESSAGE TYPE column, this statistic shows how many releases were sent and received by this H.323 stack. | |
| RAS STATISTICS FOR MESSAGES | There are two sections of RAS statistics: one for SENT (or issued) and one for RECD (or received. | |
| MESSAGE TYPE | Type of RAS messages sent and received by this H.323 stack. | |
| REQ | For each type of RAS message specified in the MESSAGE TYPE column, this statistic shows how many requests were issued/received by this H.323 stack. | |
| CON | For each type of RAS message specified in the MESSAGE TYPE column, this statistic shows how many confirmations were issued/received by this H.323 stack. | |
| REJ | For each type of RAS message specified in the MESSAGE TYPE column, this statistic shows how many rejections were issued/received by this H.323 stack. | |
