Realm Faults
This section explains how to access realm fault statistics.
Signaling
Use the following command to display SIP realm statistics:
- show sipd realms
Viewing SIP Realm Statistics
Display SIP realm statistics by using the show sipd realms command. For example:
ORACLE# show sipd realms 19:38:17-18 ---- Inbound ---- --- Outbound ---- -Latency- --- Max --- Realm Active Rate ConEx Active Rate ConEx Avg Max Burst In Out external 0 0.0 0 0 0.0 0 0.0 0.0 0 0 0 external-child 0 0.0 0 0 0.0 0 0.0 0.0 0 0 0 internal 0 0.0 0 0 0.0 0 0.0 0.0 0 0 0
Media Statistics
You can use the following commands to display information about mbcd realms:
- show mbcd realms
- show mbcd realms <realm name>
- show flows
There are also alarms that occur when the following events happen:
- out of memory
- internal
- unknown realm
- realm change
- out of bandwidth
- out of ports
Viewing MBCD Steering Port and Bandwidth Usage for Realms
Display steering ports and bandwidth usage for home, public, and private realms by using the show mbcd realms command.
For example:
acmepacket# show mbcd realms
18:46:29-2819
--- Steering Ports --- ----------- Bandwidth Usage ----------
Realm Used Free No Ports Flows Ingrss Egress Total Insuf BW
acme 0 0 0 0 0K 0K 0K 0
h323172 0 30001 0 0 0K 0K 0K 0
sip172 2 29999 0 0 0K 0K 0K 0
sip192 2 29999 0 0 0K 0K 0K 0
The information displayed includes the following:
- Used—Number of steering ports used
- Free—Number of free steering ports
- No Ports—Number of times that a steering port could not be allocated
- Flows—Number of established media flows
- Ingress—Amount of bandwidth being used for inbound flows
- Egress—Amount of bandwidth being used for outbound flows
- Total—Maximum bandwidth set for this realm
- Insuf BW—Number of times that a session was rejected due to insufficient bandwidth.
Viewing MBCD Statistics for a Specific Realm
Display media statistics for a specific realm by using the show mbcd realms <realm-name> command. This information is given for period and lifetime durations.
- Ports Used—Number of ports used
- Free Ports—Number of free ports
- No Ports Avail—Number of times no steering ports were available
- Ingress Band—Amount of bandwidth used for inbound flows
- Egress Band—Amount of bandwidth used for outbound flows
- BW Allocations—Number of times that bandwidth was allocated
- Band Not Avail—Number of times a session was rejected due to insufficient bandwidth
For example:
acmepacket# show mbcd realms sip172
18:47:31-2881 Realm=sip172
-- Period -- -------- Lifetime --------
Active High Total Total PerMax High
Ports Used 2 2 18 18 18 2
Free Ports 29999 30001 30017 30017 30017 30001
No Ports Avail - - 0 0 0 -
Ingress Band 0K 0K 0 0 0 0K
Egress Band 0K 0K 0 0 0 0K
BW Allocations 0 0 0 0 0 0
Band Not Avail - - 0 0 0 -
Total Bandwidth=0K
Steering Ports: 100% Success
Viewing MBCD Task Errors
The show mbcd errors command displays MBCD task error statistics, starting with a time stamp that shows when the current period began.
For example:
ORACLE# show mbcd errors 11:42:37-198 MBC Errors/Events ---- Lifetime ---- Recent Total PerMax Client Errors 0 0 0 Client IPC Errors 0 0 0 Open Streams Failed 0 0 0 Drop Streams Failed 0 0 0 Exp Flow Events 0 0 0 Exp Flow Not Found 0 0 0 Transaction Timeouts 0 0 0 Server Errors 0 0 0 Server IPC Errors 0 0 0 Flow Add Failed 0 0 0 Flow Delete Failed 0 0 0 Flow Update Failed 0 0 0 Flow Latch Failed 0 0 0 Pending Flow Expired 0 0 0 ARP Wait Errors 0 0 0 Exp CAM Not Found 0 0 0 Drop Unknown Exp Flow 0 0 0 Drop/Exp Flow Missing 0 0 0 Exp Notify Failed 0 0 0 Unacknowledged Notify 0 0 0 Invalid Realm 0 0 0 No Ports Available 0 0 0 Insufficient Bandwidth 0 0 0 Stale Ports Reclaimed 0 0 0 Stale Flows Replaced 0 0 0 Telephone Events Gen 0 0 0 Pipe Alloc Errors 0 0 0 Pipe Write Errors 0 0 0
There are two categories of MBCD error statistics: Client and Server.
Client statistics count errors and events encountered by applications that use the MBCD to set up and tear down media sessions:
- Client Errors—Number of errors in the client application related to MBC transactions that are otherwise uncategorized
- No Session (Open)—Number of MBC transactions creating or updating a media session that could not be sent to MBCD because the media session state information could not be located
- No Session (Drop)—Number of MBC transactions deleting a media session that could not be sent to MBCD because the media session state information could not be located
- Exp Flow Events—Number of flow timer expiration notifications received from the MBCD by all applications
- Exp Flow Not Found—Number of flow timer expiration notifications received from the MBCD by all applications for which no media session or flow information was present in the application.
- Transaction Timeouts—Number of MBC transaction timeouts
- Server statistics count errors and events encountered by MBCD
- Server Errors—Number of uncategorized errors in the MBC server
- Flow Add Failed—Number of errors encountered when attempting to add an entry to the NAT table
- Flow Delete Failed—Number of errors encountered when attempting to remove an entry from the NAT table
- Flow Update Failed—Number of errors encountered when attempting to update an entry in the NAT table upon receipt of the first packet for a media flow
- Flow Latch Failed—Number of errors when attempting to locate an entry in the NAT table upon receipt of the first packet for a media flow
- Pending Flow Expired—Number of flow timer expirations for pending flows that have not been added to the NAT table
- ARP Wait Errors—Number of errors and timeouts related to obtaining the Layer 2 addressing information necessary for sending media
- Exp CAM Not Found—This statistic shows the number that the NAT table entry for an expired flow could not find in the NAT table. This usually occurs due to a race condition between the removal of the NAT entry and the flow timer expiration notification being sent to MBCD from the NP
- Drop Unknown Exp Flow—Number of flows deleted by the MBCD because of a negative response from the application to a flow timer expiration notification
- Unk Exp Flow Missing—Number of negative responses from the application to a flow timer expiration notification for which the designated flow could not be found in MBCD's tables
- Exp Notify Failed—Number of errors encountered when the MBCD attempted to send a flow timer expiration notification to the application
- Unacknowledged Notify—Number of flow expiration notification messages sent from MBCD to the application for which MBCD did not receive a response in a timely manner
- No Ports Available—Number of steering port allocation requests not be satisfied due to a lack of free steering ports in the realm
- Invalid Realm—Number of flow setup failures due to an unknown realm in the request from the application
- Insufficient Bandwidth—Number of flow setup failures due to insufficient bandwidth in the ingress or egress realm
Viewing Realm Configurations
You can use the show realm command to display all realm-specific configurations. For example:
ORACLE# show realm 14:27:38-56SIP Realm Statistics -- Period -- ------- Lifetime ------- Realm Active Rate High Total Total PerMax High realm1 Inbound 0 0.0 0 0 0 0 0 Outbound 0 0.0 0 0 0 0 0
Viewing Realm Configurations for a Specific Realm
ORACLE# show realm realm1 realm stats for : Realm: realm1 14:29:22-40 Realm realm1 NO ACTIVITY
Viewing Monthly Minutes for a Specific Realm
You can use the show monthly minutes <realm-id> command to display the monthly minutes for a specified realm. For example:
ORACLE# show monthly-minutes realm1 14:31:33-51 Realm MinutesAllowed MinutesLeft Minutes Exceed Rejects ------------ ------------- ----------- -------------------- Recent Total PerMax realm1 10 10 0 0 0
Media Alarms
The following table lists information about the different media alarms.
| Alarm Name | Alarm ID | Alarm Severity | Cause(s) | Example Log Message | Actions |
| MBCD ALARM OUT OF MEMORY | 262145 | CRITICAL: for flow
MAJOR: for media (if server cannot allocate a new context) |
No further memory can be allocated for MBCD. | Flow: Cannot create free port list for realm.
Media Server: Failed to allocate new context. |
apSyslogMessageGenerated
apSysMgmtMediaOutofMemory trap generated |
| MBCD ALARM INTERNAL | 262146 | MINOR | An internal software error. | Internal Error. No agent for socket <IPPort>. | None |
| MBCD ALARM UNKNOWN REALM | 262147 | MAJOR: if media server is adding a new flow | Media server is unable to find realm interface. | Realm type (ingress, egress, hairpin) X, not found | apSyslogMessageGenerated
apSysMgmtUnknownRealm |
| MBCD ALARM OUT OF BANDWIDTH | 262149 | CRITICAL: failure rate = 100%
MAJOR: failure rate > or = 50% |
The realm is out of bandwidth. | Out of bandwidth | apSyslogMessageGenerated
apSysMgmtMediaBandwidthTrap |
| MBCD ALARM OUT OF PORTS | 262150 | CRITICAL: failure rate = 100%
The realm is out of steering ports. | Out of steering ports | apSyslogMessageGenerated
apSysMgmtMediaPortsTrap |
Viewing Deny ACL List
Display a list of deny ACLI entries by using the acl-show command at the topmost ACLI prompt. The following information is displayed:
- Incoming port, slot, and VLAN tag
- Source IP, bit mask, port, and port mask
- Destination IP address and port
- Protocol
- ACL entry as static and dynamic
- ACL entry index
For example:
ORACLE# acl-show deny entries: intf:vlan source-ip/mask:port/mask dest-ip/mask:port/mask prot type index Total number of deny entries = 0 Denied Entries not allocated due to ACL constraints: 0 task done
