Datapath monitor alarm
The datapath monitor alarm monitors the load on some of the major hardware components that packets traverse within the Oracle Communications Session Border Controller. These components collectively make up the datapath. The datapath overload alarm is non-health affecting, but when enabled, new SIP calls received by the Oracle Communications Session Border Controller are rejected. Existing calls remain unaffected.
The datapath monitor alarm identifies the physical interface over which the offending traffic was received.
ORACLE# display-alarms
4 alarms to show
131200 0 4 2006-05-23 06:35:49 2006-05-23 06:35:49
Count Description
1 Datapath Interface slot 0 port 0 is overloaded
For the alarm to clear, ETC CPU and ETC Memory loads must all fall below overload threshold.
Valid alarm IDs for the datapath monitor alarm are: 131200-131328
Datapath Watchdog Timer and SNMP Trap Generation
The Oracle Communications Session Border Controller's datapath watchdog timer performs periodic background checks on the continuity of the data path.
Under certain conditions, the internal data path may be interrupted. If packets do not flow long enough for the datapath watchdog timer to expire, a core dump is created and the system can automatically restart or fail over to a standby. This feature is enabled by default and is not configurable.
If SNMP is enabled, the system can also send a trap. Specifically, the system would send the apSysMgmtHardwareErrorTrap with the message Datapath Watchdog: Failures detected on the mainboard.
