Viewing System Information
This section explains how to access system level performance statistics. All the commands defined in this section are accessible in User mode.
ACLI Credit Information
Display the credit information, including the version number, for the ACLI that you are running on your system by using the show about command. This command also displays current third party licenses applicable to the software image you are running.
User Privilege Mode
Display the current level of privilege at which the user is operating on the system by using the show privilege command.
ORACLE> show privilege console user - privilege level 0 ORACLE>
Privilege level 0 means the current user is in User mode and privilege level 1 means the current user is in Superuser mode.
System Uptime
Display information about the length of time the system has been running in days, hours, minutes, and seconds (as well as the current date and time) by using the show uptime command.
ORACLE# show uptime FRI SEP 25 12:57:23 2017 - up 0 days, 22 hours, 58 minutes, 57 seconds ORACLE#
Current Date and Time
Display the current date and time for your system by using the show clock command.
ORACLE# show clock 11:51:41 est MON SEP 25 2017
Software Release Current Version
Display the version information for the release, including: the version number, the date that the current copy of the OS was made, and other information by using the show version command.
ACMESYSTEM# show version ACME PACKET 4600 SCZ8.0.0 GA (WS Build 299) Build Date=04/14/18
