Media Session Traffic and QoS Reporting
The Oracle Communications Session Border Controller (OCSBC) Quality of Service (QoS) monitor reports statistics on Real-time Transport Protocol (RTP) call flows.
QoS monitoring reports the following statistics on RTP call flows:
- Bytes and packets received
- Lost packets
- Jitter
- Maximum jitter
- Latency
- Maximum latency
These statistics are captured in the CDR for each call leg (calling and called) and for up to 2 media streams. The OCSBC gathers information for media internetworking calls and SRTP sessions. Both the RADIUS and Diameter protocols are supported.
The system captures the preceding statistics in the Call Detail Record (CDR) for both the calling leg and the called leg for up to two media streams. The system gathers information for media internetworking calls and Secure Real-time Transport Protocol (SRTP) sessions. The system supports the RADIUS protocol.
You must own the QoS license to use media session traffic and QoS reporting. The system does not support pooled transcoding.
