System Support Information for Troubleshooting
The show support-info command allows you to gather a set of information commonly requested by Oracle Support when troubleshooting customer issues.
The show support-info usage is as follows:
show support-info [standard | custom | media | signaling] {config}
- standard—Displays information for all commands the show support-info command encompasses.
- custom—Uses the /code/supportinfo.cmds file to determine what commands should be encompassed. If the file does not exist, then the system notifies you.
- media—Executes and writes out only the show media commands to the support-info.log file.
- signaling—Executes and writes all but the ACLI commands that display signaling data to the support-info.log file.
In all cases, the system displays the command’s output on the screen and writes the output to the support-log.info file (stored in /opt/logs).
Each time the show support-info command is executed a new support-info.log file is created. The previous support-info.log file is renamed by appending a .1 to the end of the file name. All additional support-info.log files are renamed to their previous number, plus 1. The Oracle Communications Session Border Controller maintains up to 6 support-info files: support-info.log and support-info.log.1 through support-info.log.5.
For example, when executing the show support-info command, a new support-info.log file is created. The existing support-info.log file is renamed to support-info.log.1. The existing support-info.log.1 file is renamed to support-info.log.2, and so on. If a support-info.log.5 exists prior to executing the show support-info command, it is deleted from the system when rotating the files.
The show support-info command combines the output of several ACLI commands into a single command. These include:
Included Data
This command combines the output of several other ACLI commands into a single command, which are listed in the table below.
| Data Group | Included Data |
| General System Commands | show clock
show version image show version boot show sipd spl show prom-info all display-alarms show process show arp show sessions show features show memory show buffers show health display-current display-run show user check-space-remaining code check-space-remaining ramdrv check-space-remaining hard-disk show process cpu all show spl |
| Physical Interface Commands | show interfaces
show media physical show media phy-stats show media host-stats show media classify show media network show media frame-stats show media tm-stats dump-etc-stats |
| SIP Commands | show registration
show sipd all show sipd agent |
| H323 Commands | show h323
show h323 h323stats show h323 agentstats show h323 stackCallstats show h323 stackPvtStats show h323 stackDisconnectInstate show h323 stacklist |
| Call Media Commands | show mbcd all
show mbcd realms stack mbcd |
| Security Commands | show security certificates brief
show security ssh-pub-key show security ssm-accelerator show security tls session-cache |
| Other Commands | ipt show all
show acl info show acl summary show acl all (only in signaling) show ip connections (only in signaling) show dns stats show enum stats show routes |
Using the ACLI show support-info command
To gather and ship information to Oracle Support using the show support-info command:
To Display information on the screen gathered from the show support-info command:
System Configuration Listing
The show support info command can append the complete running config output (show running-config) to the end of the support output file by adding the config argument to the end of any show support-info command, except show support-info custom. For example:
ORACLE# show support-info standard config
SLB Information
The following show commands have been added so that more SLB-related debug information is available in the show support-info output.
- show sip tunnels is added to show support-info and show support-info signaling
- show sip ccp is added to show support-info and show support-info signaling
- show sip lb-endpoints is added to show support-info and show support-info signaling
The following changes have been made to avoid this situation on the Oracle Session Load Balancer image (LCX image):
- show ccd ccp is added show support-info
