Viewing Active Processes
This section explains how to display statistics for active processes by displaying the task information for the system. By using the show processes command, you can view the system tasks in a table.
The information in this table is useful not only for viewing the process running on the system, but also for obtaining task names and identification numbers (TIDs in this table) for carrying out notify and stop-task commands.
This table contains the following information: names of tasks, entries, task identification codes, priority of a task, status, program counter, error numbers, and protector domain identification.
ORACLE# show processes
TaskName Id PPID Pri Status EIP Up Time RSS(kb) vMEM(kb) Proc
uscc 2115 1557 20 SLEEPING 7fe09fa86974 0:16:37.660 1366524 5932844 0
intt 2110 1 20 SLEEPING 7fafeee76350 0:16:37.670 412 19100 3
intt 2109 1 20 SLEEPING 7fafeee76350 0:16:37.670 412 19100 2
dropberr 1984 1 20 SLEEPING 7fdaa36169c3 0:16:38.710 668 22668 1
getty 1849 1 20 SLEEPING 7f75dae9c350 0:16:39.010 1016 19104 5
syslod) 1840 1 20 SLEEPING 7f5def91b350 0:16:39.030 660 19100 0
klogd 1838 1 20 SLEEPING 7ff68d78a267 0:16:39.030 660 19100 0
Accessing Process Subcommands
Display the help text for the show processes command to access the following subcommands:
ORACLE# show processes ? acliConsole acliConsole process statistics acliSSH0 acliSSH0 process statistics acliSSH1 acliSSH1 process statistics acliSSH2 acliSSH2 process statistics acliSSH3 acliSSH3 process statistics acliSSH4 acliSSH4 process statistics acliTelnet0 acliTelnet0 process statistics acliTelnet1 acliTelnet1 process statistics acliTelnet2 acliTelnet2 process statistics acliTelnet3 acliTelnet3 process statistics acliTelnet4 acliTelnet5 process statistics all display statistics for all processes berpd berpd process statistics brokerd brokerd process statistics cliWorker CliWorker process statistics collect Collector process statistics cpu display CPU Usage current current process statistics ebmd embd process statistics h323d h323d process statistics lemd lemd process statistics lid lid process statistics mbcd mbcd process statistics pusher pusher process statistics radd radd process statistics sipd sipd process statistics snmpd snmpd process statistics sysmand sysmand process statistics total total process statistics
The following table lists and defines the subcommands and additional capabilities of the show processes command.
| show processes Subcommand | Description |
| sysmand | Statistics for the sysmand process, which is related to the system startup tasks. sysmand starts and keeps track of many of the system tasks. All application tasks send their system log messages to the sysmand task and all notify requests go through sysmand. |
| lemd | Statistics for the local element management (lemd) process, which is responsible for maintaining and providing local and remote access to data (including configuration and policy data) stored in the system. |
| brokerd | Statistics for the brokerd process, which is a log concentrator and sequencer used for forwarding path and hardware monitor tasks. |
| mbcd | Statistics for the mbcd process, which is the process for the middlebox control daemon. It provides signalling applications with the ability to dynamically manage (crete, modify, delete, and receive flow event notifications) NAT entries (pinholes) for media flows via the MIBOCO protocol. |
| sipd | Statistics for sipd process statistic, which acts as a SIP server that receives and forwards them on the behalf of the requestor. sipd is responsible for processing SIP (RFC 3261) messages. It NATs the Layer 5 signaling content (for example, SIP message headers) and manages the associated media flows via tMBCD. |
| current | Current statistics for all processes. |
| total | Total statistics for all processes. |
| all | All statistics for all processes. |
| cpu | Percentage of CPU utilization by all processes. |
Viewing Statistics for all Processes
Display the statistics for all processes by using the show processes all command.
ORACLE# show processes all
12:05:39-79
Process Svcs Rcvd Sent Events Alarm Slog Plog CPU Max
12:05:09-150 (sysmand) ID=13155d60
Process Status -- Period -- -------- Lifetime --------
Active High Total Total PerMax High
Services 29 29 0 29 29 29
Messages 0 1 12 35909 322 3
Transactions 0 0 0 0 0 0
Timed Objects 31 31 0 31 31 31
Total Buffers 10 10 0 10 5 10
Alloc Buffers 5 5 0 95 33 7
Memory Chunks 83 84 12 35947 390 84
TOQ Entries 2 2 1 5326 4 2
Operations 16 44721 310
Messages Received 12 35853 296
Messages Sent 0 45 15
Partial Message 0 0 0
Partial Msg Expired 0 0 0
Partial Msg Dropped 0 0 0
Timed Events 1 5324 2
Alarms 0 0 0
System Logs 0 11 11
Process Logs 0 58 55
Load Rate 0.0 0.4
CPU Usage 0.0 11.868/531797
08:23:17-37 (acliSSH0) ID=1be38940
Services 4 4 4 4 4 4
Messages 0 0 0 0 0 0
Timed Objects 5 5 5 5 5 5
Total Buffers 0 0 0 0 0 0
Alloc Buffers 0 0 0 0 0 0
Memory Chunks 13 13 13 13 13 13
TOQ Entries 1 1 1 1 1 1
Operations 1 1 1
Messages Received 0 0 0
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/531814
17:19:33-113 (brokerd) ID=132635e0
Services 2 2 0 2 2 2
Timed Objects 2 2 0 2 2 2
Memory Chunks 11 11 0 11 11 11
TOQ Entries 0 0 0 0 0 0
Operations 8 41 31
Messages Received 3 20 16
Messages Sent 0 4 4
Timed Events 0 0 0
Alarms 0 3 3
System Logs 0 4 4
Process Logs 0 4 4
Load Rate 0.0 0.0
CPU Usage 0.0 0.006/531829
09:32:34-194 (cliWorker) ID=18a40470
Timed Objects 2 3 1 6 2 3
Memory Chunks 10 11 1 14 10 11
TOQ Entries 0 1 1 4 1 1
Operations 2 13 2
Messages Sent 0 2 1
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 5 4
Process Logs 0 6 4
Load Rate 0.0 0.0
CPU Usage 0.0 0.013/531845
12:06:39-140 (lemd) ID=18a6e400
Services 5 5 0 5 5 5
Messages 0 0 0 10 5 6
Transactions 0 0 0 3 2 2
Timed Objects 6 6 0 15 9 10
Alloc Buffers 5 5 0 9 4 7
Memory Chunks 78 78 0 91 62 86
TOQ Entries 0 0 0 6 3 3
Operations 3 8874 5
Messages Received 0 5 2
Messages Sent 0 28 21
Timed Events 0 3 2
Alarms 0 0 0
System Logs 0 26 18
Process Logs 0 36 22
Load Rate 0.0 0.0
CPU Usage 0.0 0.378/531858
12:06:54-155 (collect) ID=18aac4f0
Services 3 3 0 3 3 3
Messages 0 0 0 2 2 2
Timed Objects 3 3 0 6 6 5
Total Buffers 5 5 0 5 5 5
Alloc Buffers 2 2 0 4 4 4
Memory Chunks 12 12 0 14 14 14
TOQ Entries 0 0 0 2 2 1
Operations 35 115198 22
Messages Received 0 1 1
Messages Sent 0 6 6
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 8 8
Process Logs 0 8 8
Load Rate 0.0 0.0
CPU Usage 0.0 2.545/531872
12:07:11-171 (atcpd) ID=18ada4d0
Timed Objects 6 6 0 12 12 8
Memory Chunks 41 41 0 59 59 43
TOQ Entries 1 1 342 1059444 201 2
Operations 346 1068224 202
Messages Sent 0 8 8
Timed Events 342 1059436 201
Alarms 0 0 0
System Logs 0 10 10
Process Logs 0 12 12
Load Rate 0.0 0.0
CPU Usage 0.0 35.711/531883
12:06:39-140 (atcpApp) ID=18b0c290
Services 4 4 0 4 4 4
Timed Objects 4 4 0 7 7 6
Memory Chunks 14 14 0 16 16 16
Operations 3 8867 4
Messages Sent 0 5 5
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 7 7
Process Logs 0 8 8
Load Rate 0.0 0.0
CPU Usage 0.0 0.247/531905
12:07:39-100 (mbcd) ID=1b34afe0
Services 9 9 0 9 9 9
Timed Objects 16012 16012 0 16019 16019 16014
Total Buffers 10 10 0 10 10 10
Alloc Buffers 8 8 0 10 10 10
Memory Chunks 54 54 0 86 86 56
TOQ Entries 2 2 5 23060 15 3
Operations 5 21279 6
Messages Sent 0 30 30
Timed Events 5 23049 5
Alarms 0 0 0
System Logs 0 32 32
Process Logs 0 38 38
Load Rate 0.0 0.0
CPU Usage 0.0 1.144/531917
12:07:39-100 (lid) ID=1b59db10
Timed Objects 4 4 0 4 4 4
Alloc Buffers 3 3 0 3 3 3
Memory Chunks 12 12 0 13 13 13
TOQ Entries 0 0 0 1 1 1
Operations 2 8867 3
Messages Sent 0 6 6
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 8 8
Process Logs 0 8 8
Load Rate 0.0 0.0
CPU Usage 0.0 0.206/531930
12:07:39-100 (algd) ID=1b69e570
Services 5 5 0 6 6 5
Timed Objects 7 7 0 17 17 10
Alloc Buffers 5 5 0 7 7 7
Memory Chunks 47 47 0 81 81 49
TOQ Entries 1 1 1 5328 10 2
Operations 3 12415 5
Messages Sent 0 9 9
Timed Events 1 5320 2
Alarms 0 0 0
System Logs 0 11 11
Process Logs 0 13 13
Load Rate 0.0 0.0
CPU Usage 0.0 0.550/531940
12:07:39-100 (radd) ID=1b6e6790
Memory Chunks 14 14 0 18 18 16
Messages Sent 0 9 9
Alarms 0 0 0
System Logs 0 11 11
Load Rate 0.0 0.0
TOQ Entries 1 1 1 5321 3 2
Operations 3 14185 4
Messages Sent 0 9 9
Timed Events 1 5318 2
Alarms 0 0 0
System Logs 0 11 11
Process Logs 0 11 11
Load Rate 0.0 0.0
CPU Usage 0.0 0.358/531957
12:07:39-100 (pusher) ID=1b824c60
Memory Chunks 11 11 0 13 13 13
Operations 2 8868 4
Messages Sent 0 6 6
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 8 8
Process Logs 0 8 8
Load Rate 0.0 0.0
CPU Usage 0.0 0.232/531987
12:08:39-160 (ebmd) ID=1b856ba0
Timed Objects 7 7 0 16 16 9
Memory Chunks 56 56 0 102 102 58
TOQ Entries 2 2 2 10654 18 3
Operations 4 12417 6
Messages Sent 0 9 9
Timed Events 2 10640 4
Alarms 0 0 0
System Logs 0 11 11
Load Rate 0.0 0.0
CPU Usage 0.0 0.445/532002
12:09:19-100 (sipd) ID=1b89dfd0
Messages 0 0 0 6 4 3
Timed Objects 7 7 0 14 11 9
Alloc Buffers 3 3 0 7 4 5
Memory Chunks 48 48 0 82 79 50
TOQ Entries 2 2 11 58529 19 4
Operations 11 53204 12
Messages Received 0 3 2
Messages Sent 3 17750 30
Timed Events 11 58519 12
Alarms 0 0 0
System Logs 3 17750 32
Process Logs 3 17753 35
Load Rate 0.0 0.0
CPU Usage 0.0 8.164/532015
12:08:39-160 (lrtd) ID=1b938740
Memory Chunks 15 15 0 18 18 16
Operations 3 8868 3
Messages Sent 0 5 5
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 7 7
Process Logs 0 10 10
Load Rate 0.0 0.0
CPU Usage 0.0 0.247/532030
12:09:49-130 (h323d) ID=1b990570
Services 6 6 0 6 6 6
Messages 0 0 0 3 3 2
Timed Objects 9 9 0 19 19 9
Alloc Buffers 6 6 0 6 6 6
Memory Chunks 133 133 0 170 170 134
TOQ Entries 3 3 19 79815 25 4
Operations 14 53203 10
Messages Sent 4 17790 72
Timed Events 19 79802 16
Alarms 0 0 0
System Logs 4 17792 74
Process Logs 4 17798 80
Load Rate 0.0 0.0
CPU Usage 0.0 8.668/532048
12:09:39-120 (h248d) ID=1b9c56c0
Timed Objects 3 3 0 3 3 3
Memory Chunks 11 11 0 49 49 30
TOQ Entries 1 1 1 5322 3 1
Operations 4 12416 3
Messages Sent 0 24 24
Timed Events 1 5321 2
Alarms 0 0 0
System Logs 0 27 27
Process Logs 0 27 27
Load Rate 0.0 0.0
CPU Usage 0.0 0.301/532093
12:10:39-180 (secured) ID=1ba472c0
Timed Objects 5 5 0 11 11 7
Memory Chunks 43 43 0 65 65 45
TOQ Entries 0 0 0 7 7 1
Operations 4 8871 4
Messages Sent 0 6 6
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 8 8
Load Rate 0.0 0.0
CPU Usage 0.0 0.258/532104
12:10:39-180 (snmpd) ID=1bae1760
Memory Chunks 16 16 0 22 22 18
Operations 4 8871 4
Messages Sent 0 7 7
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 9 9
Process Logs 0 9 9
Load Rate 0.0 0.0
CPU Usage 0.0 0.244/532118
08:23:17-37 (acliSSH1) ID=1be88cd0
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532127
08:23:17-37 (acliSSH2) ID=1be89c70
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532143
08:23:17-37 (acliSSH3) ID=1be9c010
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532170
08:23:17-37 (acliSSH4) ID=1be9cbc0
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532344
12:14:39-120 (acliConsole) ID=1bedb940
Timed Objects 5 5 0 8 5 7
Memory Chunks 15 15 0 18 13 15
TOQ Entries 0 0 0 2 1 1
Operations 3 10517 177
Messages Sent 0 16 6
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 18 6
Process Logs 0 18 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.450/532357
12:05:39-179 (acliTelnet0) ID=1bef1ce0
Messages 0 0 0 43 7 5
Timed Objects 5 5 0 68 6 7
Alloc Buffers 5 5 0 37 4 7
Memory Chunks 90 90 0 147 77 92
TOQ Entries 0 0 0 45 6 1
Operations 42 21969 498
Messages Received 0 22 5
Messages Sent 0 92 15
Timed Events 0 3 1
Alarms 0 0 0
System Logs 0 73 12
Process Logs 0 73 12
Load Rate 0.0 0.4
CPU Usage 0.0 19.778/532371
14:04:54-134 (acliTelnet1) ID=1bf07ca0
Messages 1 1 1 10 5 2
Timed Objects 6 7 2 10 5 7
Alloc Buffers 5 5 0 7 4 5
Memory Chunks 15 15 1 22 13 15
TOQ Entries 1 1 1 3 1 1
Operations 4 662 282
Messages Received 0 6 4
Messages Sent 4 20 6
Timed Events 0 0 0
Alarms 0 0 0
System Logs 3 16 6
Process Logs 3 16 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.129/532384
08:23:17-37 (acliTelnet2) ID=1bf1ec90
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532397
08:23:17-37 (acliTelnet3) ID=1bf4b4c0
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532435
08:23:17-37 (acliTelnet4) ID=1bf62090
Operations 1 1 1
Messages Sent 3 3 3
Timed Events 0 0 0
Alarms 0 0 0
System Logs 6 6 6
Process Logs 6 6 6
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532454
08:24:43-23 (tTaskCheck) ID=132295f0
Services 0 0 0 0 0 0
Timed Objects 0 0 0 0 0 0
Memory Chunks 4 4 4 4 4 4
Operations 1 1 1
Messages Sent 0 0 0
Timed Events 0 0 0
Alarms 0 0 0
System Logs 0 0 0
Process Logs 0 0 0
Load Rate 0.0 0.0
CPU Usage 0.0 0.000/532474
Viewing Totals for all Processes
Display total statistics for all processes by using the show processes total command.
ORACLE# show processes total 12:32:34-94 Process Svcs Rcvd Sent Events Alarm Slog Plog CPU Max sysmand 29 35961 45 5340 0 11 58 0.0 0 acliSSH0 4 0 3 0 0 6 6 0.0 0 brokerd 2 20 4 0 3 4 4 0.0 0 cliWorke 2 0 2 0 0 5 6 0.0 0 lemd 5 5 28 3 0 26 36 0.0 0 collect 3 1 6 0 0 8 8 0.0 0 atcpd 5 1 8 1062468 0 10 12 0.0 0 atcpApp 4 1 5 0 0 7 8 0.0 0 mbcd 9 1 30 23112 0 32 38 0.0 0 lid 3 1 6 0 0 8 8 0.0 0 algd 6 1 9 5334 0 11 13 0.0 0 radd 3 1 9 5333 0 11 11 0.0 0 pusher 3 1 6 0 0 8 8 0.0 0 ebmd 5 1 9 10668 0 11 11 0.0 0 sipd 5 3 17796 58671 0 17796 17799 0.0 0 lrtd 4 1 5 0 0 7 10 0.0 0 h323d 6 1 17835 80005 0 17837 17843 0.0 0 h248d 2 0 24 5334 0 27 27 0.0 0 secured 5 1 6 0 0 8 10 0.0 0 snmpd 4 1 7 0 0 9 9 0.0 0 acliSSH1 4 0 3 0 0 6 6 0.0 0 acliSSH2 4 0 3 0 0 6 6 0.0 0 acliSSH3 4 0 3 0 0 6 6 0.0 0 acliSSH4 4 0 3 0 0 6 6 0.0 0 acliCons 3 1 16 0 0 18 18 0.0 0 acliTeln 4 22 92 3 0 73 73 0.0 0 acliTeln 4 6 20 0 0 16 16 0.0 0 acliTeln 4 0 3 0 0 6 6 0.0 0 acliTeln 4 0 3 0 0 6 6 0.0 0 acliTeln 4 0 3 0 0 6 6 0.0 0 tTaskChe 0 0 0 0 0 0 0 0.0 0
Viewing Current Statistics
Display the current statistics for all processes by using the show processes current command.
ORACLE# show processes current 12:35:12-52 Process Svcs TOQ Ops Rcvd Sent Events Alrm Slog Plog CPU Now sysmand 29 2 15 11 0 1 0 0 0 0.0 0 acliSSH0 4 1 1 0 3 0 0 6 6 0.0 0 brokerd 2 0 8 3 0 0 0 0 0 0.0 0 cliWorke 2 0 2 0 0 0 0 0 0 0.0 0 lemd 5 0 3 0 0 0 0 0 0 0.0 0 collect 3 0 34 0 0 0 0 0 0 0.0 0 atcpd 5 1 307 0 0 304 0 0 0 0.0 0 atcpApp 4 0 3 0 0 0 0 0 0 0.0 0 mbcd 9 2 7 0 0 6 0 0 0 0.0 0 lid 3 0 3 0 0 0 0 0 0 0.0 0 algd 6 1 4 0 0 1 0 0 0 0.0 0 radd 3 1 5 0 0 2 0 0 0 0.0 0 pusher 3 0 3 0 0 0 0 0 0 0.0 0 ebmd 5 2 4 0 0 2 0 0 0 0.0 0 sipd 5 2 16 0 5 16 0 5 5 0.0 0 lrtd 4 0 3 0 0 0 0 0 0 0.0 0 h323d 6 3 16 0 5 22 0 5 5 0.0 0 h248d 2 1 4 0 0 1 0 0 0 0.0 0 secured 5 0 3 0 0 0 0 0 0 0.0 0 snmpd 4 0 3 0 0 0 0 0 0 0.0 0 acliSSH1 4 1 1 0 3 0 0 6 6 0.0 0 acliSSH2 4 1 1 0 3 0 0 6 6 0.0 0 acliSSH3 4 1 1 0 3 0 0 6 6 0.0 0 acliSSH4 4 1 1 0 3 0 0 6 6 0.0 0 acliCons 3 0 3 0 0 0 0 0 0 0.0 0 acliTeln 4 0 48 0 0 0 0 0 0 0.0 0 acliTeln 4 1 4 0 4 0 0 3 3 0.0 0 acliTeln 4 1 1 0 3 0 0 6 6 0.0 0 acliTeln 4 1 1 0 3 0 0 6 6 0.0 0 acliTeln 4 1 1 0 3 0 0 6 6 0.0 0 tTaskChe 0 0 1 0 0 0 0 0 0 0.0 0
Realtime CPU usage
The show processes top command displays realtime updates of per-process CPU utilization. To quit, press "q".
ORACLE> show processes top
top - 13:57:22 up 23:48, 0 users, load average: 0.00, 0.01, 0.05
Tasks: 117 total, 2 running, 115 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.0%us, 0.0%sy, 0.0%ni,100.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 2966240k total, 398016k used, 2568224k free, 66536k buffers
Swap: 0k total, 0k used, 0k free, 116032k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1 root 20 0 3724 1100 936 S 0 0.0 0:30.13 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0 0.0 0:04.49 ksoftirqd/0
6 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
7 root RT 0 0 0 0 S 0 0.0 0:00.33 watchdog/0
8 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/1
9 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/1:0
10 root 20 0 0 0 0 S 0 0.0 0:00.08 ksoftirqd/1
11 root 20 0 0 0 0 R 0 0.0 0:02.16 kworker/0:1
12 root RT 0 0 0 0 S 0 0.0 0:00.17 watchdog/1
13 root 0 -20 0 0 0 S 0 0.0 0:00.00 khelper
418 root 20 0 0 0 0 S 0 0.0 0:00.13 sync_supers
420 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default
421 root 0 -20 0 0 0 S 0 0.0 0:00.00 kblockd
423 root 20 0 0 0 0 S 0 0.0 11:31.98 kworker/1:1
559 root 0 -20 0 0 0 S 0 0.0 0:00.00 ata_sff
570 root 20 0 0 0 0 S 0 0.0 0:00.00 khubd
Checking Remaining Space
Check the amount of storage space is available on the flash file system on the following devices by using the check-space-remaining command:
- /boot
- /code
- /crash
- /opt
- the data-disk, system-disks or a combination
For example:
ORACLE# check-space-remaining boot boot: 20127744/29760512 bytes (67%) remaining
SMP-Aware Task Load Limiting
The ability to manage CPU load is critical for highly available devices. SMP architectures require unique load limiting because a task’s threads may be spread out over several cores. The Oracle Communications Session Border Controller employs a method of determining aggregate load in its SMP environment so that resources may be evenly spread across all CPUs and applications can decrease their load when necessary. In turn, traffic may be dropped or rejected depending on the application to reduce the CPU load to an acceptable value.
Load limiting can be performed on three fundamental processing areas of the Oracle Communications Session Border Controller:
- Transport Limiting — When the system’s CPU load rises above the transport limiting value, traffic received from endpoints is dropped. The system scales back the load of the processes where network packets (TCP, SCTP, and UDP) are disassembled.
- Media Limiting — When the system’s CPU load rises above the Media limiting value, the process that creates end-to-end media interface connections begins to drop requests (changes to existing transport sessions can still occur) thereby reducing CPU load. The system replies to SIP requests that initiate transport sessions with 503 Service Unavailable (this would typically be an INVITE with SDP).
- SIP Limiting — The system can manage percent CPU utilization by limiting the number of SIP messages it processes, as follows:
- Begins rejecting SIP requests when the CPU reaches its throttling threshold, and
- Rejects all SIP requests when the CPU reaches its maximum utilization.
Calculating CPU Load Limits
This section explains how and when the Oracle Communications Session Border Controller performs SIP message throttling to limit CPU utilization. This configuration also affects IDS management information.
The Oracle Communications Session Border Controller limits CPU utilization by SIP requests using two utilization percentage points. When CPU utilization reaches the first point, the system begins to reject SIP requests. When it reaches the second point, the system rejects all SIP requests. By default, these values are 90% and 99%. The user can change these values using a sip-config option called load-limit.
The load-limit option accepts two parameters, from which it determines these levels, including:
- Minimum CPU Utilization - The CPU utilization percentage at which the system begins to throttle back on the SIP requests it processes.
- CPU Limit for Headroom Calculation - A variable the system uses to compute maximum CPU utilization, at which it stops accepting SIP requests.
Syntax for this option is:
load-limit= < Minimum CPU Utilization > [-< CPU Limit for Headroom Calculation >]
User settings include:
- Minimum CPU Utilization - The range is 15% to 100%, and the default is 90%.
- (Optional) CPU Limit for Headroom Calculation - The range is 15 to 100, and the default is 100.
The calculation the system uses to determine the maximum CPU percent utilization is shown below, with X representing the Minimum CPU Utilization, and Y representing the CPU Limit for Headroom Calculation.
X + ((Y - X) * X/Y)%
The example setting below sets the throttling threshold to 60% and the maximum utilization to 75%.
load-limit= 60-80
The calculation the system uses is 60 + (80 - 60) * 60/80 = 75
The system progressively rejects requests as CPU utilization increases. When CPU utilization is between X% and the maximum, the system accepts some new SIP requests, depending on CPU utilization and utilization configuration. The system calculates this acceptance rate using the formula below.
100 - ((Current CPU Util - X) * 100 / ((Y - X) * X/Y))
When CPU utilization reaches its maximum, it drops all new SIP requests. The system resumes accepting requests when CPU utilization falls below its maximum, and stops throttling when it falls below the Minimum CPU Utilization.
While rejecting a SIP request, the system returns a 503 service unavailable message, along with a Retry-After header. The user can configure the reject-interval using the sip-config's reject-interval=X option. The default value is 1 second.
The actual value of reject interval header embedded in the 503 message is:
RetryAfter = (100 - Acceptance Rate) /10 * rejectInterval
If this value is smaller than the configured reject-interval, the system overwrites it with the configured reject-interval value.
Note the table below, which displays some valid and invalid configuration entries.
| User Configuration | Headroom | Max CPU Limit | Configuration Valid? |
| load-limit=60 | (100 - 60) * 60 /100 = 24 | 60+24 = 84 |
Yes |
| load-limit=60-80 | (80 - 60) * 60/80 = 15 | 60+15 = 75 |
Yes |
| load-limit=80-60 | (100 - 80) * 80 / 100 = 16 | 80+16 = 96 |
No - (Upper limit < Lower limit) |
| load-limit=80-101 | (100 - 80) * 80 / 100 = 16 | 80+16 = 96 |
No - (Upper limit > 100) |
| load-limit=-70 | (100 - 90) * 90 / 100 = 9 | 90 + 9 = 99 |
No - default of 90% is used for lower limit, 100% for upper limit |
| load-limit=70- | (100 - 70) * 70 / 100 = 21 | 70 + 21 = 91 |
No - upper limit default - 100% is used |
| load-limit=- | (100 - 90) * 90 / 100 = 9 | 90 + 9 = 99 |
No - default - 90% is used. |
| load-limit=80-ABC | (100 - 80) * 80 / 100 = 16 | 80 + 16 = 96 |
No - the upper limit default of 100% is used |
| load-limit=80 90 | (100 - 80) * 80 / 100 = 16 | 80 + 16 = 96 |
