Hardware Inventory
This section describes the information you can view about the hardware components installed in Acme Packet platforms.
Components
You can view hard-coded, programmable read-only memory (PROM) information about the following Oracle Communications Session Border Controller hardware components:
- mainboard (chassis)
- CPU
- PHY cards
- Management card
- Transcoding modules
- Motherboard
- Security modules
- Power supply information
show prom-info mainboard
Display the mainboard PROM information by using the show prom-info mainboard command. For example:
ORACLE# show prom-info mainboard Contents of Main Board IDPROM Assy, NetNet4600 Oracle System Serial Number: 091132009670 Oracle Part Number: 002-0610-50 Oracle Rev: 07 Oracle FRU Part Number: 0000000 Acme Packet Part Number: 002-0850-50-05 Serial Number: 181550000576 Acme Packet FunctionalRev: 1.03 BoardRev: 05.00 PCB Family Type: Main Board ID: NetNet 4600 Main Board Options: 0 Manufacturer: MiTAC China - MSL Week/Year: 32/2017 Sequence Number: 000576 Number of MAC Addresses: 32 Starting MAC Address: 00 08 25 22 81 a0
show prom-info CPU
Display the host CPU PROM information by using the show prom-info CPU command. For example:
ORACLE# show prom-info CPU Contents of CPU IDPROM Part Number: MOD-0026-62 Manufacturer: RadiSys
show prom-info PHY0
Display PROM information for the left physical interface card by using the show prom-info PHY0 command. For example:
ORACLE# show prom-info PHY0 Contents of PHY0 IDPROM Assy, 4 Port SFP Part Number: 002-0611-58 Serial Number: 091138058055 FunctionalRev: 3.04 BoardRev: 03.00 PCB Family Type: Quad port GigE SFP PHY ID: 4 Port GigE SFP Options: 0 Manufacturer: Benchmark Electronics Week/Year: 38/2011 Sequence Number: 058055
show sfps
The show sfps command displays the EEPROM contents of the SFP modules in the system (Small Form-factor Pluggable (optical transceiver module)). This command is only applicable to the Acme Packet 4600, 6100, 6300.
ORACLE# show sfps
PHY0 SFP0 EEPROM
Identifier: Unknown or unspecified
Extended Identifier: 0x0
Connector: Unknown or unspecified
SONET Compliance Codes: 0x0
Gigabit Ethernet Compliance Codes: 0x0
Fibre Channel Link Length: 0x0
Fibre Channel Transmitter Technology: 0x0
Fibre Channel Transmission Media: 0x0
Fibre Channel Speed: 0x0
Encoding: Unspecified
Nominal Bit Rate (100MBits/sec): 0
Link Length Supported 9/125mm fiber (km): 0
Link Length Supported 9/125mm fiber (100m): 0
Link Length Supported 50/125mm fiber (10m): 0
Link Length Supported 62.5/125mm fiber (10m): 0
Link Length Supported copper (m): 0
Vendor Name: AVAGO
Vendor OUI: j
Vendor Part Number: AFBR-703SDZ
Vendor Rev Number: G2.3
PHY0 SFP1 EEPROM:
Vendor Name: AVAGO
Vendor OUI: j
