Local File System
The file system consists of 2 essential volumes and 1 or more user-defined volumes.
Acme Packet engineered systems
maintain
/boot and
/code partitions that are each 2 GB. These volumes are located on the same internal 4GB flash drives. Once a storage device is installed in the system, the
/opt and
/opt/crash volumes are moved there.
/optis located on the first system partition and is always 8 GB. Although it can be used for many purposes, it is primarily intended for core dumps, log files, CDRs, and HDR data./opt/crashis located on the second system partition. It appears as just/crash. It is the remainder of the storage device with an 8GB minimum./opt/crashis used for crash files.
Default Paths
The show platform paths command displays the default paths for system files. For example:
ORACLE# show platform paths
Filesystem paths
boot : /boot/
code : /code/
base : /opt/
crash : /opt/crash
logs : /opt/logs/
tar config : /code/config/
gz config : /code/gzConfig/
backups : /code/bkups/
import : /code/imports/
temp : /opt/tmp/
collect : /opt/collect/
running ver : /code/runVer.dat
config ver : /code/configVer.dat
running data : /opt/running/
editing data : /opt/data/
SPL files : /code/spl/
SPL bytecode : /opt/spl/
