SCTP Information
Monitoring SCTP Operations
The ACLI show ip sctp command provides basic SCTP information as shown below.
ORACLE# show ip sctp SCTP Statistics 0 input packets 0 datagrams 0 packets that had data 0 input SACK chunks 0 input DATA chunks 0 duplicate DATA chunks 0 input HB chunks 0 HB-ACK chunks 0 input ECNE chunks 0 input AUTH chunks 0 chunks missing AUTH 0 invalid HMAC ids received 0 invalid secret ids received 0 auth failed 0 fast path receives all one chunk 0 fast path multi-part data 0 output packets 0 output SACKs 0 output DATA chunks 0 retransmitted DATA chunks 0 fast retransmitted DATA chunks 0 FR's that happened more than once to same chunk 0 output HB chunks 0 output ECNE chunks 0 output AUTH chunks 0 ip_output error counter Packet drop statistics: 0 from middle box 0 from end host 0 with data 0 non-data, non-endhost 0 non-endhost, bandwidth rep only 0 not enough for chunk header 0 not enough data to confirm 0 where process_chunk_drop said break 0 failed to find TSN 0 attempt reverse TSN lookup 0 e-host confirms zero-rwnd 0 midbox confirms no space 0 data did not match TSN 0 TSN's marked for Fast Retran Timeouts: 0 iterator timers fired 0 T3 data time outs 0 window probe (T3) timers fired 0 INIT timers fired 0 sack timers fired 0 shutdown timers fired 0 heartbeat timers fired 0 a cookie timeout fired 0 an endpoint changed its cookiesecret 0 PMTU timers fired 0 shutdown ack timers fired 0 shutdown guard timers fired 0 stream reset timers fired 0 early FR timers fired 0 an asconf timer fired 0 auto close timer fired 0 asoc free timers expired 0 inp free timers expired 0 packet shorter than header 0 checksum error 0 no endpoint for port 0 bad v-tag 0 bad SID 0 no memory 0 number of multiple FR in a RTT window 0 RFC813 allowed sending 0 RFC813 does not allow sending 0 times max burst prohibited sending 0 look ahead tells us no memory in interface 0 numbers of window probes sent 0 times an output error to clamp down on next user send 0 times sctp_senderrors were caused from a user 0 number of in data drops due to chunk limit reached 0 number of in data drops due to rwnd limit reached 0 times a ECN reduced the cwnd 0 used express lookup via vtag 0 collision in express lookup 0 times the sender ran dry of user data on primary 0 same for above 0 sacks the slow way 0 window update only sacks sent 0 sends with sinfo_flags !=0 0 unordered sends 0 sends with EOF flag set 0 sends with ABORT flag set 0 times protocol drain called 0 times we did a protocol drain 0 times recv was called with peek 0 cached chunks used 0 cached stream oq's used 0 unread messages abandonded by close 0 send burst avoidance, already max burst inflight to net 0 send cwnd full avoidance, already max burst inflight to net 0 number of map array over-runs via fwd-tsn's asctpd task Statistics Control:(from app) 0 bad messages from app 0 listen (0 errors) 0 listen4 0 listen6 0 close (0 errors) 0 connect (0 errors) 0 connect4 0 connect6 0 setsockopt Control:(to app) 0 accept (0 errors) 0 accept4 0 accept6 0 connected (0 errors) 0 connected4 0 connected6 0 disconnected 0 control replies 0 Tx retries Data: 0 send requests from app (0 errors) 0 data to app (0 errors) 0 data dropped due to sendQ full Debug: Socket Allocs: 0 Frees: 0 Mblk alloc errors (0 data, 0 ctrl) IPv6 Miscellaneous 0 IPv4 Packet 0 IPv6 Easy Packet 0 IPv6 Jumbo Discarded 0 IPv6 Bad Packet 0 IPv6 Reassembled Packet 0 IPv6 Hard Packet 0 IPv6 Deleted Frag Stream 0 IPv6 Bad Fragment 0 IPv6 Single Fragment 0 IPv6 Can't Create Frag Stream 0 IPv6 Won't Create Frag Stream 0 IPv6 Current Number Frag Streams 0 IPv6 Total Frag Streams 0 IPv6 Reassemble no Mblk 0 IPv6 Reassemble Too Big ORACLE#
The ACLI show ip asctp command provides active SCTP state information as shown below.
ORACLE# show ip connections asctp A-SCTP Internet Connections Active ASCTP associations (including servers) Socket Proto Type Local Address Foreign Address State 2b2d1a84 SCTP 1to1 10.1.209.50:8192 10.1.209.47:5050 pri ESTAB 10.1.210.50:8192 10.1.210.47:5050 sec 2b2d238C SCTP 1to1 2.2.2.2:5060 LISTEN 1.1.1.1:5060 2b2d2730 SCTP 1to1 10.1.210.50:5060 LISTEN 10.1.209.50:5060 ORACLE#
