SNMP Community and Trap Receiver Management
You can view and reset the counters for SNMP community table and SNMP trap receivers using the ACLI commands described in this section.
SNMP Community Table
The SNMP community table stores information about the SNMP servers that you configure. These configurations set the community name and define what kind of information that server can access.
show snmp-community-table
The show snmp-community-table command displays all of the configuration information for the SNMP community. It also shows the total responses in and total responses out. Type show snmp-community-table followed by pressing Enter in the ACLI to use this command. For example:
ORACLE# show snmp-community-table community-name : public access-mode : READ-ONLY ip-addresses : 10.0.200.61 172.30.0.13 total requests in : 111 total responses out : 111 community-name : test access-mode : READ-ONLY ip-addresses : 172.30.0.13 10.0.200.61 total requests in : 21 total responses out : 21 community-name : test1 access-mode : READ-ONLY ip-addresses : 10.0.200.61 172.30.0.13 total requests in : 101 total responses out : 101 community-name : testipv6 access-mode : READ-ONLY ip-addresses : [fe80::221:f6ff:fe69:224]:162 total requests in : 121 total responses out : 121
Trap Receiver
The trap receiver is a network management system (NMS) to which the Oracle Communications Session Border Controller sends SNMP traps to report system events. The SNMP agent uses trap receiver information that you configure to send traps to NMSs.
When you use the ACLI show trap-receiver table command, the system displays all of the configuration information for the SNMP community and the total number of traps sent to it.
show trap-receiver
The show trap-receiver command displays all of the configuration information for the SNMP community and the total number of traps sent to it. For example:
ORACLE# show trap-receiver community-name : public filter-level : All ip-address : 10.0.0.43 total traps out : 3 community-name : test filter-level : All ip-address : 10.0.200.61 total traps out : 3 community-name : testipv6 filter-level : All ip-address : fe80::221:f6ff:fe69:224 total traps out : 103
